Object Reference : Object View and Procedure Reference : Equation : gmm : Basic GMM Options
gmm
Estimation by generalized method of moments (GMM).
The equation object must be specified with a list of instruments.
eq_name.gmm(options) y x1 [x2 x3...] @ z1 [z2 z3...]
eq_name.gmm(options) specification @ z1 [z2 z3...]
Follow the name of the dependent variable by a list of regressors, followed by the “@” symbol, and a list of instrumental variables which are orthogonal to the residuals. Alternatively, you can specify an expression using coefficients, an “@” symbol, and a list of instrumental variables. There must be at least as many instrumental variables as there are coefficients to be estimated.
In panel settings, you may specify dynamic instruments corresponding to predetermined variables. To specify a dynamic instrument, you should tag the instrument using “@DYN”, as in “@DYN(X)”. By default, EViews will use a set of period-specific instruments corresponding to lags from -2 to “-infinity”. You may also specify a restricted lag range using arguments in the “@DYN” tag. For example, to use lags from-5 to “-infinity” you may enter “@DYN(X, -5)”; to specify lags from -2 to -6, use “@DYN(X, -2, -6)” or “@DYN(X, -6, -2)”.
Note that dynamic instrument specifications may easily generate excessively large numbers of instruments.
Non-Panel GMM Options
Basic GMM Options
nocinst
Do not include automatically a constant as an instrument.
method=keyword
Set the weight updating method. keyword should be one of the following: “nstep” (N-Step Iterative, or Sequential N-Step Iterative, default), “converge” (Iterate to Convergence or Sequential Iterate to Convergence), “simul” (Simultaneous Iterate to Convergence), “oneplusone” (One-Step Weights Plus One Iteration), or “cue” (Continuously Updating”.
gmmiter=integer
Number of weight iterations. Only applicable if the “method=nstep” option is set.
w=arg
Weight series or expression.
wtype=arg (default=“istdev”)
Weight specification type: inverse standard deviation (“istdev”), inverse variance (“ivar”), standard deviation (“stdev”), variance (“var”).
wscale=arg
Weight scaling: EViews default (“eviews”), average (“avg”), none (“none”).
The default setting depends upon the weight type: “eviews” if “wtype=istdev”, “avg” for all others.
m=integer
Maximum number of iterations.
s
Use the current coefficient values in estimator coefficient vector as starting values for equations specified by list (see also param).
s=number
Determine starting values for equations specified by list. Specify a number between zero and one representing the fraction of preliminary TSLS estimates computed without AR or MA terms to be used. Note that out of range values are set to “s=1”. Specifying “s=0” initializes coefficients to zero. By default EViews uses “s=1”.
Does not apply to coefficients for AR and MA terms which are instead set to EViews determined default values.
c=number
Set convergence criterion. The criterion is based upon the maximum of the percentage changes in the scaled coefficients. The criterion will be set to the nearest value between 1e-24 and 0.2.
l=number
Set maximum number of iterations on the first-stage iteration to get the one-step weighting matrix.
coef=arg
Specify the name of the coefficient vector (if specified by list); the default behavior is to use the “C” coefficient vector.
numericderiv / ‑numericderiv
[Do / do not] use numeric derivatives only. If omitted, EViews will follow the global default.
fastderiv / ‑fastderiv
[Do / do not] use fast derivative computation. If omitted, EViews will follow the global default.
showopts / ‑showopts
[Do / do not] display the starting coefficient values and estimation options in the estimation output.
prompt
p
Print results.
Estimation Weighting Matrix Options
instwgt=keyword
Set the estimation weighting matrix type. Keyword should be one of the following: “tsls” (two-stage least squares), “white” (White diagonal matrix), “hac” (Newey-West HAC, default) or “user” (user defined).
instwgtmat=name
Set the name of the user-defined estimation weighting matrix. Only applicable if the “instwgt=user” option is set.
instlag=arg (default=1)
Whitening Lag specification: integer (user-specified lag value), “a” (automatic selection).
instinfosel=arg (default=“aic”)
Information criterion for automatic whitening lag selection: “aic” (Akaike), “sic” (Schwarz), “hqc” (Hannan-Quinn) (if “instlag=a”).
instmaxlag= integer
Maximum lag-length for automatic selection (optional) (if “instlag=a”). The default is an observation-based maximum of .
instkern=arg (default=“bart”)
Kernel shape: “none” (no kernel), “bart” (Bartlett, default), “bohman” (Bohman), “daniell” (Daniell), “parzen” (Parzen), “parzriesz” (Parzen-Riesz), “parzgeo” (Parzen-Geometric), “parzcauchy” (Parzen-Cauchy), “quadspec” (Quadratic Spectral), “trunc” (Truncated), “thamm” (Tukey-Hamming), “thann” (Tukey-Hanning), “tparz” (Tukey-Parzen).
instbw=arg (default=“fixednw”)
Kernel Bandwidth: “fixednw” (Newey-West fixed), “andrews” (Andrews automatic), “neweywest” (Newey-West automatic), number (User-specified bandwidth).
instnwlag=integer
Newey-West lag-selection parameter for use in nonparametric bandwidth selection (if “instbw=neweywest”).
instbwoffset=integer (default=0)
Apply integer offset to bandwidth chosen by automatic selection method (“bw=andrews” or “bw=neweywest”).
instbwint
Use integer portion of bandwidth chosen by automatic selection method (“bw=andrews” or “bw=neweywest”).
Covariance Options
cov=keyword
Covariance weighting matrix type (optional): “updated” (estimation updated), “tsls” (two-stage least squares), “white” (White diagonal matrix), “hac” (Newey-West HAC), “wind” (Windmeijer) “cr” (cluster robust).
The default is to use the estimation weighting matrix.
nodf
Do not perform degree of freedom corrections in computing coefficient covariance matrix. The default is to use degree of freedom corrections. (For non-cluster robust methods).
covlag=arg (default=1)
Whitening lag specification: integer (user-specified lag value), “a” (automatic selection).
covinfosel=arg (default=”aic”)
Information criterion for automatic selection: “aic” (Akaike), “sic” (Schwarz), “hqc” (Hannan-Quinn) (if “lag=a”).
covmaxlag=integer
Maximum lag-length for automatic selection (optional) (if “lag=a”). The default is an observation-based maximum of .
covkern=arg (default=“bart”)
Kernel shape: “none” (no kernel), “bart” (Bartlett, default), “bohman” (Bohman), “daniell” (Daniel), “parzen” (Parzen), “parzriesz” (Parzen-Riesz), “parzgeo” (Parzen-Geometric), “parzcauchy” (Parzen-Cauchy), “quadspec” (Quadratic Spectral), “trunc” (Truncated), “thamm” (Tukey-Hamming), “thann” (Tukey-Hanning), “tparz” (Tukey-Parzen).
covbw=arg (default=“fixednw”)
covnwlag=integer
Newey-West lag-selection parameter for use in nonparametric kernel bandwidth selection (if “covbw=neweywest”).
covbwoffset=integer (default=0)
covbwint
crtype=arg (default “cr1”)
Cluster robust weighting method: “cr0” (no finite sample correction), “cr1” (finite sample correction), when “cov=cr”.
crname=arg
Cluster robust series name, when “cov=cr”.
Panel GMM Options
cx=arg
Cross-section effects method: (default) none, fixed effects estimation (“cx=f”), first-difference estimation (“cx=fd”), orthogonal deviation estimation (“cx=od”)
per=arg
Period effects method: (default) none, fixed effects estimation (“per=f”).
levelper
Period dummies always specified in levels (even if one of the transformation methods is used, “cx=fd” or “cx=od”).
wgt=arg
GLS weighting: (default) none, cross-section system weights (“wgt=cxsur”), period system weights (“wgt=persur”), cross-section diagonal weighs (“wgt=cxdiag”), period diagonal weights (“wgt=perdiag”).
gmm=arg
GMM weighting: 2SLS (“gmm=2sls”), White period system covariances (Arellano-Bond 2-step/n-step) (“gmm=perwhite”), White cross-section system (“gmm=cxwhite”), White diagonal (“gmm=stackedwhite”), Period system (“gmm=persur”), Cross-section system (“gmm=cxsur”), Period heteroskedastic (“cov=perdiag”), Cross-section heteroskedastic (“gmm=cxdiag”).
By default, uses the identity matrix unless estimated with first difference transformation (“cx=fd”), in which case, uses (Arellano-Bond 1-step) difference weighting matrix. In this latter case, you should specify 2SLS weights (“gmm=2sls”) for Anderson-Hsiao estimation.
cov=arg
Coefficient covariance method: (default) ordinary, White cross-section system robust (“cov=cxwhite”), White period system robust (“cov=perwhite”), White heteroskedasticity robust (“cov=stackedwhite”), Cross-section system robust/PCSE (“cov=cxsur”), Period system robust/PCSE (“cov=persur”), Cross-section heteroskedasticity robust/PCSE (“cov=cxdiag”), Period heteroskedasticity robust (“cov=perdiag”).
keepwgts
Keep full set of GLS/GMM weights used in estimation with object, if applicable (by default, only weights which take up little memory are saved).
coef=arg
iter=arg (default=“onec”)
Iteration control for GLS and GMM weighting specifications: perform one weight iteration, then iterate coefficients to convergence (“iter=onec”), iterate weights and coefficients simultaneously to convergence (“iter=sim”), iterate weights and coefficients sequentially to convergence (“iter=seq”), perform one weight iteration, then one coefficient step (“iter=oneb”).
s
s=number
Determine starting values for equations specified by list. Specify a number between zero and one representing the fraction of preliminary TSLS estimates computed without AR terms to be used. Note that out of range values are set to “s=1”. Specifying “s=0” initializes coefficients to zero. By default EViews uses “s=1”.
Does not apply to coefficients for AR terms which are instead set to EViews determined default values.
m=integer
c=number
l=number
unbalsur
Compute SUR factorization in unbalanced data using the subset of available observations for a cluster.
prompt
p
Print results.
Note that some options are only available for a subset of specifications.
In a non-panel workfile, we may estimate equations using the standard GMM options. The specification:
gmmc.gmm(instwgt=white,gmmiter=2,nodf) cons c y y(-1) w @ c p(-1) k(-1) x(-1) tm wg g t
estimates the Klein equation for consumption using GMM with a White diagonal weighting matrix (two steps and no degree of freedom correction). The command:
gmmi.gmm(method=cue,instwgt=hac,instlag=1,instkern=thann,instbw=andrews,nodf) i c y y(-1) k(-1) @ c p(-1) k(-1) x(-1) tm wg g t
estimates the Klein equation for investment using a Newey-West HAC weighting matrix, with pre-whitening with 1 lag, a Tukey-Hanning kernel and the Andrews automatic bandwidth routine. The estimation is performed using continuously updating weight iterations.
When working with a workfile that has a panel structure, you may use the panel equation estimation options. The command
eq.gmm(cx=fd, per=f) dj dj(-1) @ @dyn(dj)
estimates an Arellano-Bond “1-step” estimator with differencing of the dependent variable DJ, period fixed effects, and dynamic instruments constructed using DJ with observation specific lags from period to 1.
To perform the “2-step” version of this estimator, you may use:
eq.gmm(cx=fd, per=f, gmm=perwhite, iter=oneb) dj dj(-1) @ @dyn(dj)
where the combination of the options “gmm=perwhite” and (the default) “iter=oneb” instructs EViews to estimate the model with the difference weights, to use the estimates to form period covariance GMM weights, and then re-estimate the model.
You may iterate the GMM weights to convergence using:
eq.gmm(cx=fd, per=f, gmm=perwhite, iter=seq) dj dj(-1) @ @dyn(dj)
Alternately:
eq.gmm(cx=od, gmm=perwhite, iter=oneb) dj dj(-1) x y @ @dyn(dj,-2,-6) x(-1) y(-1)
estimates an Arellano-Bond “2-step” equation using orthogonal deviations of the dependent variable, dynamic instruments constructed from DJ from period to , and ordinary instruments X(-1) and Y(-1).
See “Generalized Method of Moments” and “Panel Estimation” for discussion of the various GMM estimation techniques.
See also Equation::tsls.
