User’s Guide : Global Options : Print Setup
Print Setup
Global Options Export and Import
The Print Setup options (File/Print Setup... on the main menu) determine the default print behavior when you print an object view.
The top of the Print Setup dialog provides you with choices for the destination of printed output.
You may elect to send your output directly to the printer by selecting the Printer radio button. The drop down menu allows you to choose between the printer instances available on your computer, and the Properties button allows you to customize settings for the selected printer.
Alternatively, you may select Redirect so that EViews will redirect your output. There are three possible settings in the drop down menu: RTF file, Text file (graphs print), Frozen objects, and Spool object:
• If you select RTF file, all of your subsequent print commands will be appended to the RTF file specified in Filename (the file will be created in the default path with an “.RTF” extension). You may use the Clear File button to empty the contents of the existing file.
• If you select Text file (graphs print), all printed text output will be appended to the text file specified in Filename (the file will be created in the default path with a “.TXT” extension). Since graph output cannot be saved in text format, all printing involving graphs will still be sent to the printer. Spools will send all text and table output to the file, and will ignore all graph output.
• Frozen objects redirects print commands into newly created graph or table objects using the specified Base Object name. Each subsequent print command will create a new table or graph object in the current workfile, naming it using the base name and an identifying number. For example, if you supply the base name of “OUT”, the first print command will generate a table or graph named OUT01, the second print command will generate OUT02, and so on.
• Selecting Spool object sends subsequent print commands into a spool object in the workfile. Spool objects allow you to create collections of frozen object output (see “Spool Objects” for details).
There are also settings for text printing, CSV printing and LaTeX file printing.
The other portions of the Print Setup dialog set various default settings for spool, graph, and table printing.
The Graph defaults section has settings for printing in portrait or landscape mode, scaling the size of the graph, positioning the graph on the page, and choosing black and white or color printing. For example, the Orientation dropdown allows you print graphs in Portrait or Landscape orientation. Similarly, you may use the Graph size dropdown to scale all graphs by a fixed percentage when printing. Note that some graph settings are not relevant when redirecting output, so that portions of the dialog may be grayed out.
See “Printing Graphs” for details.
The Text/Table defaults allow you adjust settings for printing tables and text objects. You may use the Orientation dropdown allows you print graphs in Portrait or Landscape orientation, Similarly, you may use the Graph size dropdown to scale all text by a fixed percentage when printing. Some of these options are not available when redirecting output.
See “Printing Tables” for details.
The Spool defaults portion of the dialog includes settings specific to printing spool. You may use the Print mode dropdown and Apply print mode to child spools checkbox to specify where page breaks are to be used, the Object labels section to print or suppress titles and comments, or the Child size, Justification, and Size dropdowns to size and position the output.
See “Printing a Spool” for details.
We remind the user that this dialog only specifies the default settings for printing. You may override any of these settings when printing a particular job using the Print dialog or the print command.
Note that you may save your options settings to disk for backup and update your settings from an existing settings file. One use for these commands is to establish a set of global options settings which are then saved and then distributed to other users.
The optsave command ( optsave) saves a copy of the current EViews global options settings “.INI” files into a directory. Any existing option settings in the directory will be overwritten.
You may use the optset command ( optset) to replace the current EViews global options settings “.INI” files with ones from a different directory.
