Command Reference : Function Reference : Function Reference: C
@cagr
@capplyranks
@cbeta
@cbinom
@cbvnorm
@cchisq
@ceil
@cellid
@cexp
@cextreme
@cfdist
@cfirst
@cgamma
@cged
@chisq
@cholesky
@chr
@cifirst
@cilast
@cimax
@cimin
@cintercept
@claplace
@clast
@clogistic
@cloglog
@clognorm
@cmax
@cmean
@cmedian
@cmin
@cnas
@cnegbin
@cnorm
@cobs
@colcumprod
@colcumsum
@coldemean
@coldetrend
@colpctiles
@colranks
@colsort
@colstdize
@colstdizep
@columnextract
@columns
@commute
@cond
@convert
@cor
@cos
@cov
@covp
@covs
@cpareto
@cpoisson
@cprod
@cquantile
@crossid
@cstdev
@cstdevp
@cstdevs
@csum
@csumsq
@ctdist
@ctrendcoef
@ctrmean
@cumbmax
@cumbmean
@cumbmedian
@cumbmin
@cumbnas
@cumbobs
@cumbprod
@cumbquantile
@cumbstdev
@cumbstdevp
@cumbstdevs
@cumbsum
@cumbsumsq
@cumbvar
@cumbvarp
@cumbvars
@cumdn
@cumdp
@cumdz
@cummax
@cummean
@cummedian
@cummin
@cumnas
@cumobs
@cumprod
@cumquantile
@cumstdev
@cumstdevp
@cumstdevs
@cumsum
@cumsumsq
@cumvar
@cumvarp
@cumvars
@cunif
@cvalcount
@cvar
@cvarp
@cvars
@cweib
@cagr Compound annual growth rate of series (in decimal fraction).
@capplyranks Reorder the rows of the matrix using a vector of ranks.
@cbeta Beta cumulative distribution function.
@cbinom Binomial cumulative probability function.
@cbvnorm Bivariate normal cumulative distribution function.
@cchisq Chi-square cumulative distribution function.
@ceil Smallest number greater than or equal to (with optional precision).
@cellid Within cross-section identifier series for panel workfile observation.
@cexp Exponential cumulative distribution function.
@cextreme Extreme value (Type I-minimum) cumulative distribution function.
@cfdist F-distribution cumulative distribution function.
@cfirst First non-missing value in each column of a matrix.
@cgamma Gamma cumulative distribution function.
@cged Generalized error cumulative distribution function.
@chisq Upper tail of the Chi-square cumulative distribution function.
@cholesky Cholesky factor of matrix.
@chr ASCII value to string character.
@cifirst Index of the first non-missing value in each column of a matrix.
@cilast Index of the last non-missing value in each column of a matrix.
@cimax Index of the maximal value in each column of a matrix.
@cimin Index of the maximal value in each column of a matrix.
@cintercept Intercept from a trend regression performed on each column of a matrix.
@claplace Laplace cumulative distribution function.
@clast Last non-missing value in each column of the matrix.
@clogistic Logistic cumulative distribution function.
@cloglog Complimentary log-log function.
@clognorm Log normal cumulative distribution function.
@cmax Maximal value in each column of a matrix.
@cmean Mean in each column of a matrix.
@cmedian Median of each column of a matrix.
@cmin Minimal value for each column of the matrix.
@cnas Number of NA values in each column of a matrix.
@cnegbin Negative binomial cumulative probability function.
@cnorm Standard normal cumulative distribution function.
@cobs Number of non-NA values in each column of a matrix.
@colcumprod Cumulative products for each column of a matrix.
@colcumsum Cumulative sums for each column of a matrix.
@coldemean Demean each column of a matrix.
@coldetrend Detrend each column of a matrix.
@colpctiles Percentile values for each column of a matrix.
@colranks Ranks of each column of the matrix.
@colsort Sort each column of the matrix.
@colstdize Standardize each column using the sample (d.f. corrected) standard deviation.
@colstdizep Standardize each column using the population (non-d.f. corrected) standard deviation.
@columnextract Extract column from matrix.
@columns Number of columns in matrix object or group.
@commute Commutation matrix.
@cond Condition number of square matrix or sym.
@convert Converts series or group to a vector or matrix after removing NAs.
@cor Correlation of two vectors or series, or between the columns of a matrix or series in a group.
@cos Cosine of argument specified in radians.
@cov Covariance (non-d.f.corrected) of two vectors or series, or between the columns of a matrix or series in a group.
@covp Covariance (non-d.f. corrected) of two vectors or series, or between the columns of a matrix or series in a group.
@covs Covariance (d.f. corrected) of two vectors or series, or between the columns of a matrix or series in a group.
@cpareto Pareto cumulative distribution function.
@cpoisson Poisson cumulative probability function.
@cprod Product of elements in each column of a matrix.
@cquantile Quantile of each column of a matrix.
@crossid Cross-section identifier series for panel workfile observation.
@cstdev Sample standard deviation (d.f. corrected) of each column of a matrix.
@cstdevp Population standard deviation (non-d.f. corrected) of each column of a matrix.
@cstdevs Sample standard deviation (non-d.f. corrected) of each column of a matrix.
@csum Sum of the values in each column of a matrix.
@csumsq Sum of the squared values in each column of a matrix.
@ctdist Student’s cumulative distribution function.
@ctrendcoef Slope from a trend regression on each column of a matrix.
@ctrmean Trimmed mean of each column of a matrix.
@cumbmax Backward cumulative maximums of a series.
@cumbmean Backward cumulative means of a series.
@cumbmedian Backward cumulative medians of a series.
@cumbmin Backward cumulative medians of a series.
@cumbnas Backward cumulative number of missing observations of a series.
@cumbobs Backward cumulative number of (non-missing) observations of a series.
@cumbprod Backward cumulative products of a series.
@cumbquantile Backward cumulative quantiles of a series.
@cumbstdev Backward cumulative standard deviations (d.f. corrected) of a series.
@cumbstdevp Backward cumulative standard deviations (non-d.f. corrected) of a series.
@cumbstdevs Backward cumulative standard deviations (d.f. corrected) of a series.
@cumbsum Backward cumulative sums of a series.
@cumbsumsq Backward cumulative sums-of-squares of a series.
@cumbvar Backward cumulative variances (non-d.f. corrected) of a series.
@cumbvarp Backward cumulative variances (non-d.f. corrected) of a series.
@cumbvars Backward cumulative variances (d.f. corrected) of a series.
@cumdn Cumulative sum of negative (below threshold) changes in a series.
@cumdp Cumulative sum of positive (above threshold) changes in a series.
@cumdz Cumulative sum of zero (at threshold) changes in a series.
@cummax Cumulative maximums of a series.
@cummean Cumulative means of a series.
@cummedian Cumulative medians of a series.
@cummin Cumulative minimums of a series.
@cumnas Cumulative number of missing observations of a series.
@cumobs Cumulative number of (non-missing) observations of a series.
@cumprod Cumulative products of a series or the elements of a matrix.
@cumquantile Cumulative quantiles of a series.
@cumstdev Cumulative standard deviations (d.f. corrected) of a series.
@cumstdevp Cumulative standard deviations (non-d.f. corrected) of a series.
@cumstdevs Cumulative standard deviations (d.f. corrected) of a series.
@cumsum Cumulative sums of a series or the elements of a matrix.
@cumsumsq Cumulative sums-of-squares of a series.
@cumvar Cumulative variances (non-d.f. corrected) of a series.
@cumvarp Cumulative variances (non-d.f. corrected) of a series.
@cumvars Cumulative variances (d.f. corrected) of a series.
@cunif Uniform cumulative distribution function.
@cvar Population variance of each column of a matrix.
@cvarp Population variance of each column of a matrix.
@cvars Sample variance of each column of a matrix.
@cweib Weibull cumulative distribution function.
@cagr
Compound annual growth rate (in decimal fraction).
Syntax: @cagr(x, n)
x: series
n: integer
Return: series
Returns the n-th root of the total return of x over n periods:
This function is panel aware.
If x is a series of quarterly profits, then
show @cagr(x, 1)
returns a linked series containing annualized profit growth rates in decimal fraction.
See also @pccagr.
@capplyranks
Reorder the rows of a matrix using a vector of ranks.
Syntax: @capplyranks(m, v[, n])
m: matrix, vector
v: vector
n: (optional) integer
Return: matrix, vector
Apply (a column of) row ranks in the vector v to reorder the rows of a matrix m using the ranks.
• v should contain unique integers from 1 to the number of rows of m.
• If the optional argument n is specified, only the elements in column n will be reordered.
matrix m1 = @mnrnd(10, 4)
vector v1 = @ranks(m1.@col(4), "a", "i")
matrix m2 = @capplyranks(m1, v1)
reorders the rows of the matrix M1 using the ranks in V1. Note that you may use the @ranks function to obtain the ranks of a vector, but must obtain unique integer ranking for data with ties through use of the “i” or “r” option in @ranks.
matrix m3 = @capplyranks(m1, v1, 3)
reorders only the elements of column 3 of M1.
See also @sort, @colsort, and @rowsort.
See also @ranks, @colranks.
See also @rapplyranks.
@cbeta
Beta distribution cumulative distribution.
Syntax: @cbeta(x, a, b[, u])
x: number
a: number,
b: number,
u: (optional) number
Return: number
Computes the cumulative distribution function
where
and is the beta function
If the optional argument u is non-zero, return the upper-tail value: .
= @cbeta(0.5, 1, 2)
returns 0.75.
See also @dbeta, @qbeta, and @rbeta.
@cbinom
Binomial distribution cumulative probability.
Syntax: @cbinom(x, n, p)
x: number
n: integer,
p: number,
Return: number
Computes the cumulative probability function
and
where is the integer floor of .
= @cbinom(1, 5, 0.5)
returns 0.1875.
See also @dbinom, @qbinom, and @rbinom.
@cbvnorm
Bivariate normal cumulative probability.
Syntax: @cbvnorm(x, y, r)
x: number
y: number
p: number,
Return: number
Computes the cumulative distribution function for a bivariate normal with 0 mean, unit variances, and correlation r:
where
= @cbvnorm(0, 0, 0.5)
returns 0.33333....
See also @dbvnorm.
@cchisq
Chi-square cumulative distribution.
Syntax: @cchisq(x, v[, u])
x: number
v: number,
Return: number
where
= @cchisq(100, 100)
returns 0.51880....
See also @chisq, @dchisq, @qchisq, and @rchisq.
@ceil
Syntax: @ceil(x[, n])
x: number
Return: number
• @ceil(x) returns , the smallest integer that is greater than or equal to x.
• @ceil(x, n) returns , the smallest decimal number that is greater than or equal to x at the given precision.
The decimal offset n may be interpreted as the precision to use when computing the ceiling. If n is not an integer, the integer floor will be used.
= @ceil(@pi)
returns 4.
= @ceil(@pi,2)
returns 3.15.
= @ceil(-@pi)
returns -3.
See also @floor.
@cellid
Panel workfile series containing within cross-section identifier for observation.
Syntax: @cellid
Return: series
Returns index of the within cross-section identifier for each observation in the workfile.
• In a panel workfile, the index numbers identify the unique values of the within cross-section dimension.
• In a non-panel workfile, the index numbers are equivalent to sequential observation numbers.
wfcreate a 2001 2022 10
series ids = @cellid
creates a balanced 10 cross-section panel, with 22 observations per cross-section, and saves a series with indices (1 to 22) corresponding to the year of the observation.
If we have an unbalanced panel
series ubids = @cellid
will contain indices uniquely identifying the values of the all of the within cross-section identifiers observed in the workfile.
Thus, in a two-cross section panel where the first cross-section has annual observations for 1990, 1992, 1994, and 1995, and the second cross-section has observations for 1990, 1995, and 1997, the corresponding index values will be of the form (1, 2, 3, 4) and (1, 4, 5), respectively.
See also @obsrange, @crossid, and @obsid.
@cexp
Exponential cumulative distribution.
Syntax: @cexp(x, m[, u])
x: number
m: number,
Return: number
= @cexp(@log(2), 1)
returns 0.5.
See also @dexp, @qexp, and @rexp.
@cextreme
Extreme value (Type I-minimum) cumulative distribution.
Syntax: @cextreme(x, [, u])
x: number
Return: number
= @cextreme(-0.36651)
returns 0.50000....
See also @dextreme, @qextreme, and @rextreme.
@cfdist
F-distribution cumulative distribution.
Syntax: @cfdist(x, , [, u])
x: number
: number,
: number,
Return: number
where
for and 0 otherwise, and is the beta function
Note that the functions allow for fractional degrees of freedom parameters and .
= @cfdist(1, 2, 2)
returns 0.5.
See also @fdist, @dfdist, @qfdist, and @rfdist.
@cfirst
First non-missing value in each column of a matrix object.
Syntax: @cfirst(m)
m: matrix
Return: vector
Returns a vector containing the first non-missing value from each column of the matrix m.
Let M1 be an lower triangular matrix whose elements above the main diagonal are NAs. In this case,
= @cfirst(m1)
returns the main diagonal of M1 as a column vector.
See also @clast, @cifirst, and @cilast.
See also @first, @last, @ifirst, and @ilast.
@cgamma
Gamma cumulative distribution.
Syntax: @cgamma(x, b, r[, u])
x: number
b: number,
r: number,
Return: number
where
for and 0 elsewhere.
= @cgamma(2.7725, 4, 1)
returns 0.49998....
See also @dgamma, @qgamma, and @rgamma.
@cged
Generalized error cumulative distribution.
Syntax: @cged(x, r[, u])
x: number
r: number,
Return: number
where
= @cged(0.675, 2)
returns 0.75016.
See also @dged, @qged, and @rged.
@chisq
Upper tail of the Chi-square distribution.
Syntax: @chisq(x, v)
x: number
v: number,
Return: number
Returns the probability that a Chi-squared statistic with degrees of freedom exceeds .
Computes the upper tail of the cumulative distribution function
where
= @chisq(100, 100)
returns 0.48119....
See also @cchisq, @dchisq, @qchisq, and @rchisq.
@cholesky
Syntax: @cholesky(s)
s: sym
Return: matrix
Returns a matrix containing the Cholesky factorization of .
The Cholesky factorization finds the lower triangular matrix such that is equal to the symmetric source matrix .
sym s = @inner(@mrnd(10, 10))
matrix chol = @cholesky(s)
matrix orig1 = chol * chol.@t
sym orig2 = @inner(chol.@t)
computes the Cholesky, and uses it to recreate the original matrix. Note that ORIG1 is a matrix object whereas ORIG2 is a sym object.
Inverting the Cholesky may be used to obtain the matrix inverse.
sym sinv1 = @inverse(s)
matrix invchol = @inverse(chol)
matrix sinv2 = invchol.@t * invchol
sym sinv3 = @inner(invchol)
matrix id1 = sinv1 * s
matrix id2 = sinv2 * s
matrix id3 = sinv3 * s
uses properties of the inverse of the Cholesky to recreate the matrix inverse so that ID1, ID2, and ID3 are all different computations yielding the identity matrix.
See also @inverse, @rank, @issingular, @ltrim, @qr, @svd, and @svdfull.
@chr
Syntax: @chr(arg)
arg: integer
Return: string
Returns the character string corresponding to the ASCII value arg.
Valid inputs are integer values running from 0 to 255. Any invalid value will return an empty string.
string s1 = @chr(67)
string s2 = @chr(99)
returns the strings S1=“C” and S2=“c”.
See also @asc.
@cifirst
Syntax: @cifirst(m)
m: matrix
Return: vector
Returns a vector containing the index (i.e, row number) of the first non-missing value of each column of the matrix m.
= @cifirst(m1)
returns a column vector whose elements are the integers 1, 2, ..., .
See also @cfirst, @clast, and @cilast.
@cilast
Syntax: @cilast(m)
m: matrix
Return: vector
Returns a vector containing the index (i.e, row number) of the last non-missing value of each column of the matrix m.
Let M2 be an upper triangular matrix whose elements below the main diagonal are NAs. In this case,
= @cilast(m2)
See also @cfirst, @clast, and @cifirst.
@cimax
Syntax: @cimax(m)
m: matrix
Return: vector
Returns a vector containing the index (i.e, row number) of the maximal values of each column of the matrix m.
Let ID be an identity matrix. Then
= @cimax(id)
See also @cimin, @cmax, and @cmin.
@cimin
Index of the minimal value in each column of a matrix.
Syntax: @cimin(m)
m: matrix
Return: vector
Returns a vector containing the index (i.e, row number) of the minimal values of each column of m.
= @cimin(id)
returns a column -vector whose elements are 2, 1, 1, ..., 1, i.e., a 2 followed by 1s.
See also @cimax, @cmax, and @cmin.
@cintercept
Syntax: @cintercept(m)
m: matrix
Return: vector
Returns a vector of intercepts from trend regressions, each the result of applying @intercept to each column of m.
vector trend = @grid(0, 10000, 10001)
matrix m1 = @hcat(1+0.5*trend, 1+2*trend) + @mnrnd(10001, 2)
= @cintercept(m1)
produces a vector of two elements, both of which should be approximately 1.
See also @ctrendcoef, @intercept, and @trendcoef.
@claplace
Laplace cumulative distribution.
Syntax: @claplace(x[, u])
x: number
Return: number
Computes the cumulative distribution integral
where
= @claplace(@log(2))
returns 0.75.
See also @dlaplace, @qlaplace, and @rlaplace.
@clast
Syntax: @clast(m)
m: matrix
Return: vector
Returns a vector containing the last non-missing value of each column of m.
= @clast(m2)
returns the main diagonal of M2 as a column vector.
See also @cfirst, @cifirst, and @cilast.
@clogistic
Logistic cumulative distribution.
Syntax: @clogistic(x[, u])
x: number
Return: number
= @clogistic(0)
returns 0.5.
See also @dlogistic, @qlogistic, and @rlogistic.
@cloglog
Syntax: @cloglog(x)
x: number
Return: number
Compute the value of the complementary log-log function:
for .
= @cloglog(0.5)
returns -0.36651....
See also @clogistic
@clognorm
Log normal cumulative distribution.
Syntax: @clognorm(x, m, s[, u])
x: number
m: number,
s: number,
Return: number
where
= @clognorm(1, 0, 2)
returns 0.5.
See also @dlognorm, @qlognorm, and @rlognorm.
@cmax
Syntax: @cmax(m)
m: matrix
Return: vector
Returns a vector containing the maximal values of each column of m.
= @cmax(id)
returns a column vector of ones.
See also @cimax, @cimin, and @cmin.
@cmean
Syntax: @cmean(m)
m: matrix
Return: vector
Returns a vector containing the mean values of each column of the matrix m.
Let MAT be an matrix of IID exponential numbers with mean 1. Then
= @cmean(mat)
returns an -vector whose elements are approximately 1 for large .
See also @csum and @coldemean
@cmedian
Syntax: @cmedian(m)
m: matrix
Return: vector
Returns a vector containing the median values of each column of m.
= @cmean(mat)
returns an -vector whose elements are approximately for large .
See also @cmean and @cquantile.
@cmin
Syntax: @cmin(m)
m: matrix
Return: vector
Returns a vector containing the minimal values of each column of the matrix m.
= @cmin(id)
returns a column vector of zeros.
See also @cimax, @cimin, and @cmax.
@cnas
Syntax: @cnas(m)
m: matrix
Return: vector
Returns a vector containing the number of missing values in each column of the matrix m.
= @cnas(m1)
returns a column vector whose elements are the integers 0, 1, ..., .
See also @cobs.
@cnegbin
Negative binomial distribution cumulative probability.
Syntax: @cnegbin(x, n, p)
x: number
n: number,
p: number,
Return: number
and
= @cnegbin(9, 10, 0.5)
returns 0.5.
See also @dnegbin, @qnegbin, and @rnegbin.
@cnorm
Standard normal cumulative distribution.
Syntax: @cnorm(x[, u])
x: number
Return: number
where
= @cnorm(-1.96)
returns 0.02499....
See also @logcnorm, @dnorm, @qnorm, and @rnorm.
@cobs
Syntax: @cobs(m)
m: matrix
Return: vector
Returns a vector containing the number of non-missing values in each column of the matrix m.
= @cobs(m1)
returns a column vector whose elements are the integers , , ..., 1.
See also @cnas.
@colcumprod
Syntax: @colcumprod(m)
m: matrix, vector
Returns a matrix where each column contains the cumulative products of the values of the corresponding column of m.
For each element of the output, compute the cumulative product of the values in m from the start of the column up to the current row:
Note that this function is prone to numeric overflow.
Let M1 be an matrix of IID uniform numbers drawn from the unit interval. Then
= @colcumprod(m1)
generates an matrix whose columns converge to 0 at an exponential rate.
See also @colcumsum.
See also @cumprod and @cumsum.
See also @cprod, @csum, and @csumsq.
@colcumsum
Syntax: @colcumsum(m)
m: matrix, vector
Returns a matrix where each column contains the cumulative sums of the values of the corresponding column of m.
For each element of the output, compute the cumulative sum of the values in m from the start of the column up to the current row:
= @colcumsum(m1)
generates an matrix whose columns diverge to infinity at a linear rate.
See also @colcumprod.
@coldemean
Syntax: @coldemean(m)
m: matrix
Return: matrix
Returns the matrix containing the results from subtracting the column mean from each column of m.
For each element of the output matrix :
for the mean of column where
(18.1)
where is the number of non-missing values in the column. If there are missing values in a column, they are ignored and the number of rows is adjusted.
matrix m1 = @mnrnd(50, 4)
matrix m1d = @coldemean(m1)
demeans each column of M1 and places the results in M1D.
This operation is equivalent to
vector m1means = @cmeans(m1)
matrix m2d = m1 - @kronecker(@ones(m1.@rows), m1means.@t)
where @cmeans is used to compute the column means of M1.
See also @demean, @detrend, and @coldetrend.
@coldetrend
Syntax: @coldetrend(m)
m: matrix
Return: matrix
Returns the matrix containing the results from detrending each column of m.
Detrending produces the residuals of the OLS regression of the data in column versus an intercept and implicit time trend. For each element of the output matrix :
where and are the intercept and slope coefficients of a regression of the data in column on a constant and time trend. If there are missing values in a column, they are ignored.
matrix m1d = @coldetrend(m1)
detrends each column of M1 and places the results in M1D.
vector cintercepts = @cintercept(m1)
vector ctrendcs = @ctrendcoef(m1)
matrix m2d = m1 - @kronecker(@ones(m1.@rows), cintercepts.@t) - @kronecker(@range(0, m1.@rows-1), ctrendcs.@t)
where @cintercept and @ctrendcoef are used to compute the coefficients of the column trend regressions.
See also @cintercept and @ctrendcoef.
See also @demean, @detrend, and @coldemean.
@colpctiles
Syntax: @colpctiles(m[, o])
m: matrix, vector
o: (optional) string
Returns a matrix where each column contains the percentiles of the values of the corresponding column of m
The option o controls the direction of the ranking: “a” (ascending - default) or “d” (descending).
Let MAT be a matrix with two columns. Then
= @colpctiles(mat)
and
= @hcat(@pctiles(mat.@col(1)), @pctiles(mat.@col(2)))
are equivalent.
See also @pctiles.
@colranks
Syntax: @colranks(m[, o, t])
m: matrix, vector
t: (optional) string
Returns a matrix where each column contains the ranks of the values of the corresponding column of m.
The o option controls the direction of the ranking:
• “a” (ascending - default) or “d” (descending).
The t option controls tie-handling:
• Ties are broken according to the setting of t: “i” (ignore), “f” (first), “l” (last), “a” (average - default), “r” randomize.
If you wish to specify tie-handling options, you must also specify the order option (e.g., @colranks(x, "a", "i")).
= @colranks(m1, "d")
returns a matrix whose i-th column ranks the elements in the i-th column of M1 so that the largest element in said column has a rank of 1.
See also @ranks and @rowranks.
See also @capplyranks and @rapplyranks.
@colsort
Syntax: @colsort(m[, o])
m: matrix, vector
Returns a matrix where each column contains the sorted values of the corresponding column of m.
Let M1 be a matrix. Then
= @colsort(m1, "d")
returns a matrix whose i-th column is the sorted (from largest at the top to smallest at the bottom) version of the i-th column in M1.
See also @sort and @rowsort.
See also @ranks, @colranks, and @rowranks.
@colstdize
Syntax: @colstdize(m)
m: matrix, vector
Returns the matrix containing the results from standardizing each column of m.
For each element of the output:
for the mean and the sample (d.f. corrected) standard deviation of column where
(18.2)
matrix m1s = @colstdize(m1)
standardizes each column of M1 and places the results in M1D.
See also @stdize, @stdizep, @colstdizep, and @coldemean.
@colstdizep
Syntax: @colstdizep(m)
m: matrix, vector
for the mean and the population (non-d.f. corrected) standard deviation of column where
(18.3)
matrix m1s = @colstdizep(m1)
See also @colstdize, @stdize, @stdizep, and @coldemean.
@columnextract
Extract a column from the matrix.
Syntax: @columnextract(m, n)
m: matrix, sym
n: integer
Return: vector
Extract a vector from column n of the matrix object m, where m is a matrix object.
Note that we recommend that extraction be performed using the newer “.col” object data member functions. See “Matrix Data Members” and “Sym Data Members” and the examples below.
matrix m1 = @mnrnd(20, 5)
vector v1 = @columnextract(m1,3)
extracts column 3 from the matrix M1.
sym s1 = @mnrnd(5, 5)
vector v2 = @columnextract(s1, 5)
Alternately, using the data member functions, we have
vector v1a = m1.@col(3)
vector v2a = s1.@col(5)
See also @rowextract and @subextract.
See “Matrix Data Members” and “Sym Data Members”.
@columns
Syntax: @columns(x)
m: matrix, sym, group
Return: integer
matrix m1 = @mnrnd(10, 3)
scalar sc1 = @columns(m1)
assigns the value 3 to the scalar object SC1.
See also @rows.
@commute
Commutation matrix.
Syntax: @commute(m, n)
m: integer
n: integer
Return: matrix
The commutation matrix transforms the vectorization of a matrix to the vectorization of its transpose.
Given the matrix , returns the matrix , which satisfies
matrix m1 = @mnrnd(10, 5)
vector diff = @commute(10, 5) * @vec(m1) - @vec(m1.@t)
demonstrates the properties of the commutation matrix since DIFF equals zero.
See also @duplic, @duplicinv, and @elimin.
@cond
Condition number of matrix.
Syntax: @cond(m[, n])
m: matrix, sym
Return: number
Returns the condition number of a square matrix or sym, m.
The condition number is the product of the norm of the matrix divided by the norm of the inverse.
If the norm option n is omitted, the infinity norm is used to determine the condition number. Possible norms are “-1” for the infinity norm, “0” for the Frobenius norm, and an integer “n” for the norm.
matrix m1 = @mnrnd(10, 10)
scalar sc1 = @cond(m1)
computes the infinity norm of the matrix M1.
sym s1 = @inner(m1)
scalar sc2 = @cond(s1, 2)
computes the norm of the symmetric matrix S1.
See also @norm
@convert
Converts series, alpha, or group to matrix objects after removing NAs.
Syntax: @convert(o[, s])
o: series, alpha, group
s: (optional) sample string or object
Return: vector, svector, matrix
Convert data in the series (numeric or alpha) or group object into a vector (numeric or alpha) or group after removing rows with an NA or “”.
• If o is a series, @convert returns a vector from the values of o using the optional sample s or the current workfile sample. If any observation has the value “NA”, the observation will be omitted from the vector.
• If o is an alpha series, @convert returns an svector from the values of o using the optional sample s or the current workfile sample.
• If o is a group, @convert returns a matrix from the values of o using the optional sample object smp or the current workfile sample.
The data for series in o are placed in the columns of the resulting matrix in the order they appear in the group spreadsheet. If any of the series for a given observation has the value “NA”, the observation will be omitted for all series.
Note that if the group contains alpha series, they are treated as numeric series with all NA values for purposes of this conversion.
For a conversion method that preserves NAs, see stomna.
vector v2 = @convert(ser1)
vector v3 = @convert(ser2, "2000m12 2022m01")
converts the numeric series SER1 and SER2 into the vectors V2 and V3. V2 contains all non-missing elements in the current workfile sample, while V3 contains non-missing elements from 2000m12 to 2022m01.
sample smpl "2000m10 2022m05"
svector a2 = @convert(alp1)
svector a3 = @convert(alp2, smpl)
converts the alpha series ALP1 and ALP2 into the svectors A2 and A3. A2 contains all non-missing (non-blank) elements in the current workfile sample, while A3 contains non-missing elements from 2000m10 to 2022m05.
matrix m1 = @convert(grp1)
matrix m2 = @convert(grp1, smpl)
converts the series in the group GRP1 into the matrices M1 and M2.
M1 uses all non-missing observations in the current workfile sample, while M2 uses non-missing observations in the sample object from 2000m10 to 2022m05. Note that if GRP1 contains alpha series, they are treated as numeric series with all NA values for purposes of this conversion.
See also mtos, stom, stomna, and ttom.
@cor
Computes the correlation between two vectors, or between the columns of a matrix.
Syntax: @cor(x, y)
x: vector, rowvector, or series
y: vector, rowvector, or series
Return: scalar
Syntax: @cor(m)
m: matrix object or group
Return: sym
For series and group calculations, EViews will use the current workfile sample.
If used with two vector or series objects, @cor returns the correlation between the two vectors or series.
scalar sc1 = @cor(v1, v2)
If used with a matrix object or group, @cor calculates the correlation matrix between the columns of the matrix object or the series in the group object.
sym s1 = @cor(mat1)
See also @cov, @covp, and @covs.
@cos
Compute the cosine of x (specified in radians).
Syntax: @acos(x)
x: number
Return: number
= @cos(@pi)
returns -1.
See also @acos, @asin, @atan, @sin, and @tan.
@cov
Compute population (non-d.f. corrected) covariance between two vectors, or between the columns of a matrix.
Syntax: @cov(v1, v2)
v1: vector, rowvector, or series
v2: vector, rowvector, or series
Return: scalar
Syntax: @cov(o)
o: matrix object or group
Return: sym
Compute covariances using as the divisor in the moment calculation.
If used with two vector or series objects, @cov returns the population covariance between the two vectors or series.
scalar sc1 = @cov(v1, v2)
If used with a matrix object or group, @cov calculates the population covariance matrix between the columns of the matrix object or the series in the group object.
sym s1 = @cov(mat1)
See also @cor, @covp, and @covs.
@covp
Syntax: @covp(v1, v2)
Return: scalar
Syntax: @covp(o)
Return: sym
Equivalent to @cov.
If used with two vector or series objects, @covp returns the population covariance between the two vectors or series.
scalar sc1 = @covp(v1, v2)
If used with a matrix object or group, @covp calculates the population covariance matrix between the columns of the matrix object.
sym s1 = @covp(mat1)
See also @cor, @cov, and @covs.
@covs
Compute sample (d.f. corrected) covariance between two vectors, or between the columns of a matrix.
Syntax: @covs(v1, v2)
Return: scalar
Syntax: @covs(o)
Return: sym
If used with two vector or series objects, @covs returns the sample covariance between the two vectors or series.
scalar sc1 = @covs(v1, v2)
If used with a matrix object or group, @covs calculates the sample covariance matrix between the columns of the matrix object.
sym s1 = @covs(mat1)
See also @cor, @cov, and @covp.
@cpareto
Pareto cumulative distribution.
Syntax: @cpareto(x, k, a[, u])
x: number
k: number,
a: number,
Return: number
= @cpareto(2, 1, 2)
returns 0.75.
See also @dpareto, @qpareto, and @rpareto.
@cpoisson
Poisson distribution cumulative probability.
Syntax: @cpoisson(x, m)
x: number
m: number,
Return: number
and
= @cpoisson(10, 10)
returns 0.58303....
See also @dpoisson, @qpoisson, and @rpoisson.
@cprod
Syntax: @cprod(m)
m: matrix
Return: vector
Returns a vector containing the column products. One should be aware of overflow.
vector colprods = @cprod(m1)
computes the column products for the matrix M1 and places them in COLPRODS.
See also @colcumprod and @colcumsum.
See also @csum and @csumsq.
@cquantile
Quantiles for each column of a matrix.
Syntax: @cquantile(m, q)
m: matrix
q: number
Return: vector
Returns the column q-quantile using the Cleveland definition. q must be between zero and one.
= @cquantile(m1, .5)
and
= @cmedian(m1)
are equivalent.
See also @cmedian.
@crossid
Panel workfile series containing cross-section identifier (index) for observation.
Syntax: @crossid
Return: series
Returns the index of the cross-section identifier for each observation in the workfile.
• In a panel workfile, the index numbers identify the cross-section.
• In a non-panel workfile, there is a single cross-section, so the function returns 1.
series ids = @crossid
returns a series with integer index values identifying the cross-section.
If you have an unbalanced panel,
ids.freq
displays a one-way tabulation of the cross-section ids, so that you can see the number of observations in each cross-section.
See also @obsrange, @cellid, and @obsid.
@cstdev
Syntax: @cstdev(m)
m: matrix
Return: vector
Returns the column sample standard deviation.
= @cstdev(mat)
returns a (column) vector whose i-th element is the sample standard deviation of the i-th column of MAT.
See also @cmean and @cstdevs.
@cstdevp
Syntax: @cstdevp(m)
m: matrix
Return: vector
Returns the column population standard deviation.
= @cstdevp(mat)
returns a (column) vector whose i-th element is the population standard deviation of the i-th column of MAT.
See also @cstdev and @cstdevs.
@cstdevs
Syntax: @cstdevs(m)
m: matrix
Return: vector
= @cstdevs(mat)
See also @cstdev and @cstdevp.
@csum
Syntax: @csum(m)
m: matrix
Return: vector
Returns a vector containing the summation of the rows in each column of the matrix m.
vector colsums = @csum(m1)
computes the column sums for the matrix M1 and places them in COLSUMS.
See also @cprod and @csumsq.
@csumsq
Syntax: @csumsq(m)
m: matrix
Return: vector
Returns the sum of squared values for each column of m.
vector colsumsqs = @csumsq(m1)
computes the column sums-of-squares for matrix M1 and places them in COLSUMSQS.
See also @cprod and @csum.
@ctdist
Student’s cumulative distribution.
Syntax: @ctdist(x, v[, u])
x: number
v: number,
Return: number
where
Note that , yields the Cauchy distribution.
= @ctdist(-12.71, 1)
returns 0.02499....
See also @tdist, @dtdist, @qtdist, and @rtdist.
@ctrendcoef
Syntax: @ctrendcoef(m)
m: matrix
Return: vector
Returns a vector of slopes from a trend regression, each the result of applying @trendcoef to the columns of m.
= @ctrendcoef(m1)
produces a vector of two elements, the first of which should be close to 0.5, the second of which should be approximately 2.
See also @cintercept, @intercept, and @trendcoef.
@ctrmean
Syntax: @ctrmean(m, p)
m: matrix
p: number
Return: vector
Returns a vector of trimmed means, each the result of applying @trmean to columns of m.
matrix m = @mrnd(100,10)
m(1,1) = 1000
= @cmean(m)
returns a vector of column means of M, the first of which should be approximately 10.495, the rest of which should be around 0.5.
= @ctrmean(m,1)
returns a vector of trimmed column means of M, all of which should be approximately 0.5.
See also @trmean.
@cumbmax
Decreasing samples calculation of the maximum.
Syntax: @cumbmax(x, [s])
x: series
Return: series
The backward maximum for each observation may be written as the maximum value from the current observation to the last period, so that
where the order statistics represent data for the observations (), ordered from low to high, where is the last period.This function is panel aware.
show @cumbmax(x)
generates a linked series of the backward cumulative maximum of the series x.
See also @cumbmin.
For the forward variant of this function, see @cummax.
@cumbmean
Decreasing samples calculation of the mean of the values in x.
Syntax: @cumbmean(x[, s])
x: series
Return: series
Compute the mean of the values in x from to the end of the workfile or from to the end of the optional sample s:
where is the last period of the cumulative process, and .
show @cumbmean(x)
generates a linked series of the backward cumulative mean of the observations in series x.
See also @cumbsum, @cumbsumsq, and @cumbprod.
For the forward variant of this function, see @cummean.
@cumbmedian
Backward cumulative median of a series.
Decreasing samples calculation of the median.
Syntax: @cumbmedian(x, [s])
x: series
Return: series
The median for each observation may be written as:
where order statistics represent data for the observations (), ordered from low to high, and is the last period.
show @cumbmedian(x)
generates a linked series of the backward cumulative median of the series x.
See also @cumbquantile.
For the forward variant of this function, see @cummedian.
@cumbmin
Backward cumulative minimum of a series.
Decreasing samples calculation of the minimum.
Syntax: @cumbmin(x, [s])
x: series
Return: series
The backward maximum as the minimum value from the current observation to the end of the sample, so that:
where the order statistics represent data for the observations (), ordered from low to high, and is the last period.
show @cumbmin(x)
generates a linked series of the backward cumulative minimum of the series x.
See also @cumbmax.
For the forward variant of this function, see @cummin.
@cumbnas
Backward cumulative missing observations of a series.
Increasing samples calculation of the missing (NA) observations in .
Syntax: @cumbnas(x[, s])
x: series
Return: series
Compute the number of missing (NA) values in x from to the end of the workfile or from to the end of the optional sample s.
series x = @recode(@rnd > 0.5, @nrnd, na)
show x @cumbnas(x)
produces a spreadsheet with two columns correspond to x and @cumbnas(x). The second series (which corresponds to @cumbnas(x)) starts at the count returned by @nas(x) and decrements in those observations where x is NA.
See also @cumbobs.
For the forward variant of this function, see @cumnas.
@cumbobs
Backward cumulative observations of a series.
Increasing samples calculation of the number of non-missing observations in .
Syntax: @cumbobs(x[, s])
x: series
Return: series
Compute the number of non-missing values in x from to the end of the workfile or from to the end of the optional sample s.
show x @cumbobs(x)
produces a spreadsheet with two columns correspond to x and @cumbobs(x). The second series (which corresponds to @cumbobs(x)) starts at the count returned by @obs(x) and decrements in those observations where x is non-NA.
See also @cumbnas.
For the forward variant of this function, see @cumobs.
@cumbprod
Decreasing samples calculation of the product of the values in x.
Syntax: @cumbprod(x[, s])
x: series
Return: series
Compute the product of the values in x from to the end of the workfile or from to the end of the optional sample s:
where is the last period of the cumulative process. Note that this function is prone to numeric overflow.
show @cumbprod(x)
generates a linked series of the backward cumulative product of the observations in series x.
See also @cumbsum, @cumbmean, and @cumbsumsq.
For the forward variant of this function, see @cumprod.
@cumbquantile
Increasing samples calculation of the quantile value where approximately 100*q percent of the data is less than or equal to the value,
Syntax: @cumbquantile(x, q, [s])
x: series
q: number, series
Return: series
• The quantile value q must satisfy .
• The cumulative quantiles are computed using the Rankit-Cleveland definition of the empirical distribution function: .
To compute the cumulative backward quantile for observation find , the smallest rank such that:
where the order statistics represent data for the observations (), ordered from low to high, and is the last period. For purposes of computing , tied ranks are assumed to take the last tied value.
Then the quantile is computed as:
where the interpolating constant is
for the smallest integer where . In the leading case where there are no tied values, .
show @cumbquantile(x, 0.1)
generates a linked series of the backward cumulative 10th percentile of the series x.
See also @cumbmedian.
For the forward variant of this function, see @cumquantile.
@cumbstdev
Backward cumulative standard deviations (d.f. adjusted) of a series.
Equivalent to @cumbstdevs.
Decreasing sample calculation of the square root of the sample (d.f. adjusted) Pearson product moment variance.
Syntax: @cumbstdev(x, [s])
x: series
Return: series
The sample standard deviation is calculated for each observation as:
where is the last period of the cumulative process, , and is the mean of over the last observations.
show @cumbstdev(x)
generates a linked series of the backward cumulative sample standard deviations of the series x.
See also @cumbstdevs, @cumbstdevp, @cumbvar, @cumbvarp, and @cumbvars.
For the forward variant of this function, see @cumstdev.
@cumbstdevp
Backward cumulative standard deviations (population, non-d.f. corrected).
Decreasing samples calculation of the square root of the population (non-d.f. adjusted) Pearson product moment variance.
Syntax: @cumbstdevp(x, [s])
x: series
Return: series
The population standard deviation is calculated for each observation as:
show @cumbstdevp(x)
generates a linked series of the backward cumulative population standard deviations of the series x.
See also @cumbstdev, @cumbstdevs, @cumbvar, @cumbvarp, and @cumbvars.
For the forward variant of this function, see @cumstdevp.
@cumbstdevs
Backward cumulative sample standard deviations (sample, d.f. corrected) of a series.
Decreasing sample calculation of the square root of the sample (d.f. corrected) Pearson product moment variance.
Syntax: @cumbstdevs(x, [s])
x: series
Return: series
show @cumbstdevs(x)
See also @cumbstdev, @cumbstdevp, @cumbvar, @cumbvarp, and @cumbvars.
For the forward variant of this function, see @cumstdevs.
@cumbsum
Decreasing samples calculation of the sum of the values in x.
Syntax: @cumbsum(x[, s])
x: series
Return: series
Compute the sum of the values in x from to the end of the workfile or from to the end of the optional sample s:
show @cumbsum(x)
generates a linked series of the backward cumulative sum of the observations in series x.
See also @cumbmean, @cumbsumsq, and @cumbprod.
For the forward variant of this function, see @cumsum.
@cumbsumsq
Backward cumulative sums of squares of a series.
Decreasing samples calculation of the sum of the squared values in x.
Syntax: @cumbsumsq(x[, s])
x: series
Return: series
Compute the sum of the squared values in x from to the end of the workfile or from to the end of the optional sample s:
show @cumbsumsq(x)
generates a linked series of the backward cumulative sums of squares of the series x.
See also @cumbsum, @cumbmean, and @cumbprod.
For the forward variant of this function, see @cumsumsq.
@cumbvar
Equivalent to @cumbvarp.
Decreasing samples calculation of the population (non-d.f. corrected) Pearson product moment variance.
Syntax: @cumbvar(x, [s])
x: series
Return: series
The population variance for each observation is calculated as:
show @cumbvar(x)
generates a linked series of the backward cumulative population variance of the series x.
See also @cumbstdev, @cumbstdevs, @cumbstdevp, @cumbvarp, and @cumbvars.
For the forward variant of this function, see @cumvar.
@cumbvarp
Backward cumulative variance (population, non-d.f. corrected) of a series.
Syntax: @cumbvarp(x, [s])
x: series
Return: series
show @cumbvarp(x)
See also @cumbstdev, @cumbstdevs, @cumbstdevp, @cumbvar, and @cumbvars.
For the forward variant of this function, see @cumvarp.
@cumbvars
Backward cumulative variances (sample, d.f. corrected) of a series.
Decreasing samples calculation of the sample (d.f. corrected) Pearson product moment variance.
Syntax: @cumbvars(x, [s])
x: series
Return: series
The sample variance for each observation is calculated as:
show @cumbvars(x)
generates a linked series of the backward cumulative sample variance of the series x.
See also @cumbstdev, @cumbstdevs, @cumbstdevp, @cumbvar, and @cumbvarp.
For the forward variant of this function, see @cumvars.
@cumdn
Cumulative process of negative (below threshold) changes.
Compute the partial sum process of negative (below the threshold y) changes in the series beginning in the specified date.
Syntax: @cumdn(x, d[, y, s])
x: series
d: string
y: (optional) number
Return: series
Consider the partial sum decomposition of a variable given a initial value as where , , and are the partial sum processes of the differences for positive, negative, and zero changes in relative to the threshold y:
This function returns the negative partial sums for the current or specified sample.
• The date d specification determines .
• Values for dates prior to d will be NAs.
• The optional argument specifies the threshold value. By default .
The code below produces a graph of a sine wave x and @cumdn applied on x.
wfcreate u 50
series x = @sin(@pi*@trend/4)
group g x @cumdn(x,1)
g.line
See also @cumdp, @cumdz, @dcumdp, @dcumdn, and @dcumdz.
@cumdp
Cumulative process of positive (above threshold) changes.
Compute the partial sum process of positive (above the threshold y) changes in the series x beginning in the specified date.
Syntax: @cumdp(x, d[, y, s])
x: series
d: string
Return: series
This function returns the positive partial sums for the current or specified sample.
• The date d string specification determines .
The code below produces a graph of a sine wave x and @cumdp applied on x.
wfcreate u 50
group g x @cumdp(x,1)
g.line
See also @cumdn, @cumdz, @dcumdp, @dcumdn, and @dcumdz.
@cumdz
Cumulative process of zero (at threshold) changes.
Compute the partial sum process of positive (at the threshold y) changes in the series x beginning in the specified date.
Syntax: @cumdz(x, d[, y, s])
x: series
d: string
Return: series
This function returns the zero change for the current or specified sample.
show @cumdz(x, 2001, 1)
produces a linked series of @cumdz applied to x where the starting date is 2001 and the threshold value is set to 1.
See also @cumdn, @cumdp, @dcumdp, @dcumdn, and @dcumdz.
@cummax
Cumulative maximum of a series.
Increasing samples calculation of the maximum.
Syntax: @cummax(x, [s])
x: series
Return: series
The maximum for each observation may be written as
where the order statistics represent data from the beginning of the workfile or sample s, up to the current observation (), ordered from low to high.
series x = @cummax(@rnd)
generates a random process x that converges in probability to 1.
See also @cummin.
For the backward variant of this function, see @cumbmax.
@cummean
Increasing samples calculation of the mean of the values in x.
Syntax: @cummean(x[, s])
x: series
Return: series
Compute the cumulative mean of the values in x from the start of the workfile or sample s, up to the current observation:
series x = @cummean(@nrnd)
generates a random process x that converges in probability to 0.
See also @cumsum, @cumsumsq, and @cumprod.
For the backward variant of this function, see @cumbmean.
@cummedian
Cumulative median of a series.
Increasing samples calculation of the median.
Syntax: @cummedian(x, [s])
x: series
Return: series
series x = @cummedian(@rnd)
generates a random process x that converges in probability to 0.5.
See also @cumquantile.
For the backward variant of this function, see @cumbmedian.
@cummin
Cumulative minimum of a series.
Increasing samples calculation of the minimum.
Syntax: @cummin(x, [s])
x: series
Return: series
The minimum for each observation may be written as
series x = @cummin(@rnd)
See also @cummax.
For the backward variant of this function, see @cumbmin.
@cumnas
Cumulative missing observations of a series.
Syntax: @cumnas(x[, s])
x: series
Return: series
Compute the number of missing (NA) values in x from the start of the workfile or sample s, up to the current observation.
show x @cumnas(x)
produces a spreadsheet with two columns correspond to x and @cumnas(x). The second series (which corresponds to @cumnas(x)) starts at 0 (if the first observation in x is non-NA) or 1 (if the first observation in x is NA) and increments in those observations where x is NA.
See also @cumobs.
For the backward variant of this function, see @cumbnas.
@cumobs
Cumulative observations of a series.
Syntax: @cumobs(x[, s])
x: series
Return: series
Compute the number of non-missing values in x from the start of the workfile or sample s, up to the current observation.
show x @cumobs(x)
produces a spreadsheet with two columns correspond to x and @cumobs(x). The second series (which corresponds to @cumobs(x)) starts at 0 (if the first observation in x is NA) or 1 (if the first observation in x is non-NA) and increments in those observations where x is non-NA.
See also @cumnas.
For the backward variant of this function, see @cumbobs.
@cumprod
Cumulative products of a series or of the elements of a matrix.
• Compute the cumulative product of the values in the series x from the start of the workfile or sample s, up to the current observation:
Syntax: @cumprod(x[, s])
x: series, matrix, vector
Return: series, matrix, vector
• Compute the cumulative product of the elements of the matrix in vec order.
Syntax: @cumprod(m)
m: matrix, vector
show @cumprod(x)
produces a linked series whose elements are the cumulative products of the elements in x.
See also @cumsum, @cummean, and @cumsumsq.
For the backward variant of this function for series, see @cumbprod.
@cumquantile
Syntax: @cumquantile(x, q, [s])
x: series
q: number, series
Return: series
• The cumulative quantiles are computed using the Rankit-Cleveland definition of the empirical distribution function: for observation , .
To compute the cumulative quantile for observation find , the smallest rank such that:
where the order statistics represent data from the beginning of the workfile or sample s, up to the current observation (), ordered from low to high. For purposes of computing , tied ranks are assumed to take the last tied value.
show @cumquantile(@nrnd, 0.975)
generates a linked series that converges in probability to 1.95996... (the 97.5th percentile of the standard normal distribution).
See also @cummedian.
For the backward variant of this function, see @cumbquantile.
@cumstdev
Cumulative standard deviations (d.f. adjusted) of a series.
Equivalent to @cumstdevs.
Increasing samples calculation of the square root of the sample (d.f. adjusted) Pearson product moment variance.
Syntax: @cumstdev(x, [s])
x: series
Return: series
where is the mean of over the first observations.
series x = @nrnd
group g @cumstdev(x) @cumstdevs(x) @cumstdevp(x)
g.line
plots @cumstdev(x), @cumstdevs(x), and @cumstdevp(x) together. Note that @cumstdev(x) and @cumstdevp(x) are equivalent. All three series converge in probability to 1.
See also @cumstdevs, @cumstdevp, @cumvar, @cumvars, and @cumvarp.
For the backward cumulative variant of this function, see @cumbstdev.
@cumstdevp
Cumulative standard deviations (population – non-d.f. adjusted).
Increasing samples calculation of the square root of the population (non-d.f. adjusted) Pearson product moment variance.
Syntax: @cumstdevp(x, [s])
x: series
Return: series
series x = @nrnd
g.line
See also @cumstdev, @cumstdevs, @cumvar, @cumvars, and @cumvarp.
For the backward variant of this function, see @cumbstdevp.
@cumstdevs
Cumulative sample standard deviations (sample – d.f. adjusted) of a series.
Syntax: @cumstdevs(x, [s])
x: series
Return: series
series x = @nrnd
g.line
See also @cumstdev, @cumstdevp, @cumvar, @cumvars, and @cumvarp.
For the backward variant of this function, see @cumbstdevs
@cumsum
Cumulative sums of a series or of the elements of a matrix.
• Compute the sum of the values in the series x from the start of the workfile or sample s, up to the current observation:
Syntax: @cumsum(x[, s])
x: series
Return: series
• Compute the cumulative sum of the elements of the matrix in vec order.
Syntax: @cumsum(m)
m: matrix, vector
Compute the cumulative sum of the values in x from the start of the workfile or sample s, up to the current observation:
series x = @cumsum(@nrnd)
generates a random walk process x with standard normal errors, initialized at a draw from the standard normal distribution.
See also @cummean, @cumsumsq, and @cumprod.
For the backward variant of this function for series, see @cumbsum.
@cumsumsq
Cumulative sums of squares of a series.
Increasing samples calculation of the sum of the squared values in x.
Syntax: @cumsumsq(x[, s])
x: series
Return: series
Compute the cumulative sum of the squared values in x from the start of the workfile or sample s, up to the current observation:
series x = @cumsumsq(@nrnd) / (@trend + 1)
See also @cumsum, @cummean, and @cumprod.
For the backward variant of this function, see @cumbsumsq.
@cumvar
Cumulative variances (population – non-d.f. adjusted) of a series.
Equivalent to @cumvarp.
Increasing samples calculation of the population (non-d.f. adjusted) Pearson product moment variance.
Syntax: @cumvar(x, [s])
x: series
Return: series
series x = @nrnd
group g @cumvar(x) @cumvars(x) @cumvarp(x)
g.line
plots @cumvar(x), @cumvars(x), and @cumvarp(x) together. Note that @cumvar(x) and @cumvarp(x) are equivalent. All three series converge in probability to 1.
See also @cumstdev, @cumstdevs, @cumstdevp, @cumvars, and @cumvarp.
For the backward variant of this function, see @cumbvar.
@cumvarp
Cumulative variance (population – non-d.f. adjusted) of a series.
Syntax: @cumvarp(x, [s])
x: series
Return: series
where is the mean of over the data first observations.
series x = @nrnd
g.line
See also @cumstdev, @cumstdevs, @cumstdevp, @cumvar, and @cumvars.
For the backward variant of this function, see @cumbvarp.
@cumvars
Cumulative variances (sample – d.f. adjusted) of a series.
Increasing samples calculation of the sample (d.f. adjusted) Pearson product moment variance.
Syntax: @cumvars(x, [s])
x: series
Return: series
series x = @nrnd
g.line
See also @cumstdev, @cumstdevs, @cumstdevp, @cumvar, and @cumvarp.
For the backward variant of this function, see @cumbvars.
@cunif
Uniform cumulative distribution.
Syntax: @cunif(x, a, b[, u])
x: number
a: number
b: number,
Return: number
= @cunif(4, 1, 6)
returns 0.6.
See also @dunif, @qunif, and @runif.
@cvalcount
Count of matching values in each column.
Syntax: @cvalcount(x, y)
x: data object
y: value or string
Return: vector
The number of elements in each column of x that match y. Note that numeric matches require an exact match.
Let X be a matrix. Then
= @cvalcount(x, 2)
returns a vector containing the number of elements in each column of X that take the value 2.
See also @valcount.
@cvar
Variance (population) of each column of a matrix.
Syntax: @cvar(m)
m: matrix
Return: vector
Returns the column population variance.
= @cvar(mat)
returns a (column) vector whose i-th element is the population variance for the i-th column of MAT.
See also @cstdev, @cstdevs, @cstdevp, and @cvarp.
@cvarp
Syntax: @cvarp(m)
m: matrix
Return: vector
= @cvarp(mat)
See also @cstdev, @cstdevs, @cstdevp, and @cvar.
@cvars
Variance (sample) of each column of a matrix.
Syntax: @cvars(m)
m: matrix
Return: vector
Returns the column sample variance.
= @cvars(mat)
returns a (column) vector whose i-th element is the sample variance for the i-th column of MAT.
See also @cstdev, @cstdevs, @cstdevp, @cvar, and @cvarp.
@cweib
Weibull cumulative distribution.
Syntax: @cweib(x, m, a[, u])
x: number,
m: number,
a: number,
Return: number
(18.4)
(18.5)
= @cweib(@log(2), 1, 1)
returns 0.5.
See also @dweib, @qweib, and @rweib.
