Command Reference : Function Reference : Function Reference: F
@fact
@factlog
@fdist
@fileexist
@fill
@filledmatrix
@filledrowvector
@filledsym
@filledvector
@first
@firstsby
@floor
@folderexist
@fracdiff
@fv
@fact Factorial function.
@factlog Natural logarithm of the factorial function.
@fdist Upper tail of F-distribution.
@fileexist Check for existence of a file on disk.
@fill Vector initialized from a list of values.
@filledmatrix Matrix initialized with scalar value.
@filledrowvector Rowvector initialized with scalar value.
@filledsym Sym initialized with scalar value.
@filledvector Vector initialized with scalar value.
@first The first non-missing value in the vector or series.
@firstsby First non-missing value in a series for each specified group.
@floor Largest number less than or equal to with optional precision.
@folderexist Check for existence of a folder on disk.
@fracdiff Fractional difference of series data.
@fv Future value of annuity payments and (optional) initial lump sum receipt.
@fact
Factorial function.
Syntax: @fact(x)
x: integer
Return: number
for integer . Note that this function is subject to overflow for large .
• @gamma may be used to obtain results for real valued .
• Related, stable calculations for the logarithm of @fact may be obtained using @factlog.
= @fact(3)
returns 6.
See also @factlog.
@factlog
Syntax: @factlog(x)
x: number
Return: number
for . Returns
• @gammalog may be used to obtain results for real valued .
= @factlog(3)
returns 1.79175... (the natural log of 6).
See also @fact.
@fdist
Syntax: @fdist(x, , )
x: number
: number,
: number,
Return: number
Computes the upper tail of the cumulative distribution integral
where
for and 0 otherwise, and is the beta function
Note that the functions allow for fractional degrees of freedom parameters and .
= @fdist(1, 2, 2)
returns 0.5.
See also @cfdist, @dfdist, @qfdist, and @rfdist.
@fileexist
Syntax: @fileexist(str)
str: string
Return: integer
Check for an file’s existence. str should contain the full path and file name of the file you want to check for. Returns a “1” if the file exists, and a “0” if it does not exist.
!exists = @fileexist("myfile.prg")
checks for the existence of MYFILE.PRG in the EViews working directory.
!exists = @fileexist("c:\users\william tell\myfile.prg")
checks for the existence of MYFILE.PRG in the specified directory.
See also @wdir and @folderexist
@fill
Syntax: @fill(n1[, n2, n3, ...])
n#: number
Return: vector
Returns a vector containing the elements specified by the arguments to the function. The vector will have length equal to the number of arguments. The maximum number of arguments is 96.
vector v = @fill(1, 4, 6, 21.3)
Will return a 4 element vector, where the first element is set to 1, the second to 4, the third to 6 and the fourth to 21.3.
vector pvals = @cnorm(@fill(-1.65, -1, .5, 1.76))
evaluates the cumulative normal distribution function for the vector of values {-1.65, -1.0, 0.5, 1.76}.
See @filledmatrix, @filledrowvector, @filledsym, and @filledvector.
See also @sfill.
@filledmatrix
Syntax: @filledmatrix(n1, n2, n3)
n1: integer
n2: integer
n3: number
Return: matrix
Returns a matrix with n1 rows and n2 columns, where each element contains the value n3.
= @filledmatrix(4, 3, @pi)
returns a matrix whose elements all equal to .
See @fill, @filledrowvector, @filledsym, and @filledvector.
@filledrowvector
Syntax: @filledrowvector(n1, n2)
n1: integer
n2: integer
Return: rowvector
Returns a rowvector of length n1, where each element contains the value n2.
= @filledrowvector(3, @pi)
returns a 3-element rowvector whose elements all equal to .
See @fill, @filledmatrix, @filledsym, and @filledvector.
@filledsym
Syntax: @filledsym(n1, n2)
n1: integer
n2: number
Return: sym
Returns an sym, where each element contains n2.
= @filledsym(3, @pi)
returns a sym object whose elements all equal to .
See @fill, @filledmatrix, @filledrowvector, and @filledvector.
@filledvector
Syntax: @filledvector(n1, n2)
n1: integer
n2: number
Return: vector
Returns a vector of length n1, where each element contains the value n2.
= @filledvector(3, @pi)
returns a 3-element (column) vector whose elements all equal to .
See @fill, @filledmatrix, @filledrowvector, and @filledsym.
@first
The first non-missing value in the data object.
Syntax: @first(m)
m: numeric or alphanumeric object
Return: number or string
Returns scalar containing the first non-missing values of the single column data object. The series and alpha versions use the current workfile sample.
Let V be a vector of length 4 whose elements are NA, NA, 4.2, and 1.7. Then
= @first(v)
returns 4.2.
See also @cfirst, @clast, @cifirst, and @cilast.
See also @last, @ifirst, and @ilast.
@firstsby
First non-missing value in a series or alpha for each group defined by distinct values.
Syntax: @firstsby(x, y[y1, y2, ... yn, s])
x: series, alpha
y1...yn series, alpha, group
s: (optional) sample string or object
Return: number, string
First non-missing value in each distinct value group computed using the current workfile or specified sample.
show @firstsby(x, g1, g2)
produces a linked series of the by-group first non-missing values of the series x, where members of the same group have identical values for both g1 and g2.
See also @lastsby.
@floor
Largest integer less than or equal to (with optional precision).
Syntax: @floor(x[, n])
x: number
n: (optional) integer
Return: number
• @floor(x) returns , the largest integer that is less than or equal to x.
• @floor(x, n) returns , the largest decimal number that is less than or equal to x at the given precision.
The decimal offset n may be interpreted as the precision to use when computing the floor. If n is not an integer, the integer floor will be used.
= @floor(@pi)
returns 3.
= @floor(@pi,2)
returns 3.14.
= @floor(-@pi)
returns -4.
See also @ceil.
@folderexist
Syntax: @folderexist(str)
str: string
Return: integer
str should contain the full path of the folder you want to verify. Returns a “1” if the folder exists, and a “0” if it does not exist.
!exists = @folderexist("backup")
checks for the existence of the folder BACKUP in the EViews working directory.
!exists = @folderexist("c:\users\william tell\backup")
checks for the existence of BACKUP in the specified directory.
See also @wdir and @fileexist.
@fracdiff
Syntax: @fracdiff(x, y[, s])
x: series
y: series
Return: series
Returns for series x for :
(18.6)
This function is panel aware.
show @fracdiff(@demean(x),1.5)
applies to the demeaned version of the series x.
See also d.
@fv
Syntax: @fv(r, n, x[, v, bf])
r: number
n: integer
x: number
v: (optional) number
bf: (optional) number
Return: number
Compute future (negative) value of payment of an n-period annuity, with payments x and rate r, and optional receipt of (positive) initial lump sum v.
A non-zero value for the optional bf indicates that the payments are made at the beginning of periods (annuity due) instead of ends (ordinary annuity).
• The future value of an initial lump sum followed by n-periods of ordinary annuity payments:
• The future value of an initial lump sum followed by annuity due payments is:
= @fv(0.05, 10, 100, 1000)
returns the value 371.1054, meaning that the issuer of the annuity stands to profit $371.11 once payments are done.
See also @nper, @pmt, @pv, and @rate.
