Object Reference : Object Command Summary : T
T
Tab settings UI:2102
Table UI:827, O:846
add comment to cell O:849
assigning numbers to cells C:58
assigning strings to cells C:58
assignment with formatting C:59
attribute setting O:860
background color C:64
borders and lines C:64, O:870
cell annotation UI:834
cell format UI:832, C:62
cell merging UI:835
color UI:833
column resize UI:832
column width See Column width.
command entries O:848
comments UI:834
convert from matrix C:751
copy UI:836, O:851
copy range of cells O:850
copy table to new table C:505
copy to other windows programs UI:836
create using freeze C:368
creating C:57
creating by freezing a view C:57
customization UI:831, C:67
data members O:847
decimal format code C:59
declare C:58, O:877
delete cells from a table O:852
delete column O:853
delete row O:853
display format for cells See Display format
edit UI:829
editing UI:829
export C:66
extract from spool O:709
fill (background) color for cells O:861
font UI:833, C:64, O:863
formatting UI:832
gridlines UI:832
horizontal line C:488
indentation for cells See Indentation
insert cells into a table O:855
insert column O:856
insert in spool O:712
insert row O:856
insert table in new table C:505
justification for cells See Justification
merging UI:835, O:872
paste as unformatted text UI:837
print UI:836, C:66
procs O:846
read data from foreign source UI:838
row heights C:60, O:868
row resize UI:832
save to disk UI:837, C:66, C:484, O:858
selecting cells UI:827
set and format cell contents C:486
set column width See Column width.
sort rows UI:830, O:876
text color for cells C:64, O:874
title UI:832, O:878
views O:846
write to file C:66
table O:877
tablemode O:723
@tablenames C:780
tabplace C:505
Tabs
See Page
Tabulation
n-way UI:613, O:365
one-way UI:444, O:621
Talworth function 1:1319
@tan C:592, C:619
Tangent C:592, C:619
TAR UI:1357, O:181
TARCH UII:1150
See ARCH.
t-distribution C:595
t-distribution function
CDF C:607
density C:609
inverse CDF C:616
random number generator C:618
Template
by command C:51, O:352
dated data tables UI:595, O:352
graphs UI:816, O:325
template O:325
@temppath C:781
Test
See also Hypothesis tests, Specification test and Goodness of fit
adding variables O:178
ARCH UII:1092, O:119
Arrelano-Bond serial correlation UII:1962, O:42
breakpoint UII:1100, UII:1102, UII:1104, O:148
Chow C:313, O:63
coefficient UII:1070
correlated random effects O:163, O:536
cross-section dependence UII:1956, II:2018, O:58, O:604
CUSUM O:168
CUSUM of squares O:168
Durbin-Wu-Hausman UII:987, O:88
Engle-Granger O:67
exogeneity O:959
for equality of matrix values C:713
for equality of values C:568, C:609
for inequality of matrix values C:718
for inequality of values C:568, C:614
for missing value C:568, C:611
for serial correlation C:302, O:51
for serial correlation in VAR O:911
Goodness-of-fit O:180
Granger causality UI:638, II:2010, C:308, O:334
Hansen instability UII:1181, O:67
heteroskedasticity UII:1091, O:119
heteroskedasticity in VAR O:964
Johansen cointegration C:315, O:336, O:516
Johansen cointegration from a VAR O:917
lag exclusion (Wald) O:960
mean, median, variance equality O:401
mean, median, variance equality by classification O:670
multiple breakpoint UII:1104, O:148
omitted variables C:506, O:178, O:544
Park added variable UII:1184
Park added variable test O:67
Phillips-Ouliaris O:67
pooled UII:1876
redundant fixed effects O:95
pool O:525
redundant variables C:507, O:179, O:545
RESET UII:1118, C:478, O:165
residual UII:1087
seasonal unit root UII:1547
simple mean, median, variance hypotheses O:671
stability tests UII:1099
unit root C:517, O:401, O:549, O:675
unit root (seasonal) O:643
unit root with break UII:1531, O:602
variance ratio UII:1569, O:680
Wald O:193, O:432, O:552, O:756, O:841
White UII:1093, O:119
testadd C:506, O:178, O:544
testbtw O:401
testby O:670
testdrop C:507, O:179, O:545
testexog O:959
testfit O:180
testlags O:960
teststat O:671
Text UI:838, O:880
append O:881
attribute setting O:886
clear O:882
data members O:880
declare O:506, O:887
procs O:880
views O:880
text O:506, O:887
Text color O:393, O:657
Text file
import C:390
import as matrix UI:161, C:400, O:446, O:560, O:787, O:975
import as table UI:161, UI:838, C:407
open as workfile UI:36, C:530
save workfile as C:546
Text object
save to disk O:885
Text series O:4
textdefault O:326
@theil C:577
Theil inequality coefficient UI:453, UII:1052, C:577
Themes UI:2090
then C:781
Theoretical distribution graph UI:733
save data UI:571, O:610
Three stage least squares See 3sls (Three Stage Least Squares)
threshold O:181
Threshold autoregression UI:1357, O:181
Threshold GARCH (TARCH) UII:1150
Threshold regression UI:1357
smooth UII:1373, O:181
Thresold regression O:181
tic C:511
Time
current C:781
current as string C:667
@time C:781
Time series functions UI:191, C:570, C:572
Timer C:511, C:782
title O:724, O:878
Title bar UI:49, UI:90, UI:113
to C:782
To (lag range) UII:901
Tobit UII:1253, C:310, O:61
@toc C:782
toc C:511
TOC ini 1:212, 1:238
Toolbar UI:49, UI:113
topmargin O:725
Trace
of matrix C:750
@trace C:750
trace O:501, O:506
track O:507
Tracking model variables UII:1826
TRAMO/SEATS
in X-13 UI:482, UI:486
Tramo/Seats UI:518, O:672
tramoseats O:672
Transition equation UII:1754
Transition results
Markov switching 1:1451, UI:1737, O:143, O:176, O:185, O:945, O:957, O:961
outputting 1:1454, UI:1739
switching regression 1:1451, UI:1737, O:143, O:176, O:185, O:945, O:957, O:961
Transpose UI:576
matrix C:750
@transpose C:750
transprobs O:185, O:961
Trend C:706, C:743
coefficient from regression C:578, C:619, C:708, C:750
intercept from trend regression C:575
panel data UII:1904
panel functions C:628
See also @trend.
@trend C:624, C:629
in panel C:629
@trendc C:624, C:628
@trigamma C:592
Trigonometric functions C:592
@trim C:86, C:668
Trimmed mean C:578, C:620
matrix columns C:708
Mean
trimmed C:751
@trmean C:751
@trrendcoef C:578, C:619, C:750
Truncated dependent variable UII:1263, C:310, O:61
estimation UII:1263
fitted index UII:1265
forecasting UII:1265
log likelihood UII:1263
residuals UII:1264
Truncation point UII:1264
TSD data format UI:356
tsls
pool O:545
single equation C:507, C:512, O:186
system O:840
TSP portable data format UI:409, C:349
t-statistics
retrieve from equation UII:906, O:40
retrieve from pool O:512
retrieve from system O:807
ttom C:751
Tukey UI:734
Tukey-Hamming kernel
cointegrating regression UII:1173, C:325, C:327, C:328, O:74, O:77, O:78
GMM estimation UII:984, C:380, O:112
long-run covariance estimation UI:635, O:372
panel cointegrating regression 1:1977
robust standard errors UII:939, C:307, C:424, C:510, O:56, O:131, O:184
technical details UII:2154
Tukey-Hanning kernel
Tukey-Parzen kernel
Tuning constants
M-estimation 1:1318, O:170
S-estimation 1:1323
Two-stage least squares
See 2sls (Two-Stage Least Squares).
Type
field in database query UI:345
