Object Reference : Object Command Summary : I
I
Icon UI:103
Identification
Box-Jenkins UII:1000
GMM UII:976
nonlinear models UII:953
Identity
in model UII:1780
in system UII:1595
@identity C:722
Identity matrix C:722
extract column C:753
@idname O:511
@idnameest O:511
if C:769
If condition in samples UI:138
If statement C:144
else clause C:145, C:763
end of condition C:764
matrix comparisons C:146
start of condition C:769
then C:781
@iff C:569, C:610
IGARCH UII:1150, C:298, O:45
IHS C:349
IHS Global Insight data UI:396, UI:397, C:349
IHS Magellan data UI:397
Im, Pesaran and Shin UII:1566, C:517, O:675
@imax C:575, C:723, C:724
IMF C:349
@imin C:575
@implode C:724
import C:390, O:446
Import data UI:146, C:390, C:530
append to end UI:157
as matrix UI:161, C:400, O:446, O:560, O:787, O:975
as table UI:161, UI:838, C:407
dated read UI:152
for pool objects UII:1848
from ASCII UI:150
from spreadsheet UI:150
from workfile UI:150
matched read UI:155
matrix C:281
name conflicts UI:161
options UI:159
See also Foreign data.
sequential read UI:157
using a pool object UII:1852
importattr C:398
importmat C:400, O:446, O:560, O:787, O:975
importtbl C:407
impulse O:932
Impulse response UII:1651, O:932
See also VAR.
ARMA models UII:1024, O:49
generalized impulses UII:1653
standard errors UII:1652
structural decomposition UII:1653
transformation of impulses UII:1653
user specified impulses UII:1653
Impute NAs C:571, C:606
Include
file in a program file C:769
program file C:154
include C:769
Incomplete beta C:589
derivative C:590
integral C:589
inverse C:590
Incomplete gamma C:591
derivative C:591
inverse C:591
Incorrect functional form UII:1093, UII:1118
Indentation C:63
alpha series O:15
coef O:28
groups O:391
matrix O:464
rowvector O:571
series O:656
spools UI:848
sym O:798
table O:869
vector O:986
Independence test UI:452, UII:1579, O:598
Index
fitted from binary models UII:1241, C:365, O:94
fitted from censored models UII:1259, C:365, O:94
fitted from truncated models UII:1265, C:365, O:94
Index functions
matrix first non-missing C:695
matrix last non-missing C:696
row-wise first non-NA C:587
row-wise last non-NA C:587
row-wise maximum C:587
row-wise minimum C:587
series first non-NA C:723
series last non-NA C:723
series maximum C:723
series minimum C:724
vector first non-NA C:723
vector last non-NA C:723
vector maximum C:723
vector minimum C:724
Indicator functions C:627
Individual sample UI:195
Influence statistics UII:1125, O:124
Information criterion
Akaike UII:909, UII:2147, O:37
Hannan-Quinn UII:2147, O:38
Schwarz UII:909, UII:2147
infstats O:124
@ingrp UII:1846
INI file
replace from existing location C:437
save to new location C:436
Ini file
load key C:772
save key C:776
Initial parameter values C:468
Initialize
add factor O:474
matrix object O:445, O:786, O:973
series O:617
@inlist C:598, C:627
@inner C:575, C:611, C:724
Inner product C:575, C:611, C:724
moving C:583, C:585, C:612, C:613
innov O:486
Innovation UII:994
Insert
columns in tables O:856
observation UI:132
rows in tables O:856
table cells O:855
@insert C:85, C:652
insert O:712
insertcells O:855
insertcol O:856
Insertion point UI:91
in command line C:5
insertrow O:856
@instr C:83, C:653
Instrumental variable UII:963, C:507, C:512, O:186
dropped instruments UII:986
for 2SLS with AR specification UII:968
for nonlinear 2SLS UII:971
identification (single equation) UII:965
identification (systems) UII:1597
in systems UII:1595, O:840
order condition UII:965
rank UII:966
summary of UII:986, O:125
tests UII:986
using PDL specifications UII:919
weak UII:972
weak instruments UII:988, O:194
with pooled data UII:1885
instsum O:125
Integer dependent variable UII:1273
Integer random number C:478
Integrated series UII:1519
Integrity (database) UI:353
Interactive mode C:5
Intercept
matrix columns C:697
@intercept C:575, C:725
Intercept from trend regression C:725
Intercept in equation UII:900, UII:906
Interpolate UI:469, O:594, O:626
Intraday data UI:33
date functions C:113
in samples UI:140
@inv C:569, C:611, C:715
Invalid date identifiers UI:295
@inverse C:725
Inverse of matrix C:725
element by element C:715
Inverse Wishart density C:608
Inverse Wishart density (Cholesky covariance) C:608
Inverse Wishart density (Cholesky inverse covariance) C:608
Inverse Wishart density (inverse covariance) C:608
Inverse Wishart distribution C:597
Inverse Wishart random number generator C:617
Inverse Wishart random number generator (Cholesky covariance) C:617
Inverse Wishart random number generator (Cholesky inverse covariance) C:617
Inverse Wishart random number generator (inverse covariance) C:617
Inverted AR roots UII:1020
Inverted MA roots UII:1020
ipf O:211
ipolate O:626
Irregular data UI:271
Irrelevant variable test UII:1084
@isempty C:83, C:653
@isna UI:196, C:568, C:611
@isobject C:770
@ispanel C:621
@isperiod C:624
@issingular C:726
@isvalidgroup C:770
@isvalidname C:771
Iterate to convergence GMM
single equation UII:979, UII:984, C:379, O:110
Iterated principal factors O:211
Iteration UII:2126, C:422, O:52, O:61, O:129
failure to improve message UII:2127
in models UII:1830
in nonlinear least squares UII:949
optimization method UII:2126, C:422, O:52, O:61, O:129
