Object Reference : Object Command Summary : G
G
Gamma
distribution C:594
@gamma C:591
Gamma function C:591
CDF C:606
density C:608
derivative C:590, C:591
incomplete C:591
incomplete derivative C:591
incomplete inverse C:591
inverse CDF C:616
logarithm C:591, C:610
random number generator C:617
second derivative C:592
@gammader C:591
@gammainc C:591
@gammaincder C:591
@gammaincinv C:591
@gammalog C:591, C:610
GARCH UII:1137
ARCH-M model UII:1139
asymmetric component model UII:1154
backcasting UII:1143
component models (CGARCH) UII:1153
display conditional standard deviation O:104, O:823
estimate equation C:295, O:42
estimation in EViews UII:1140
examples UII:1145
exponential GARCH (EGARCH) UII:1151, C:296, O:43
GARCH(1,1) model UII:1137
GARCH(p,q) model UII:1139
generate conditional variance series O:138, O:830
initialization UII:1143
Integrated GARCH (IGARCH) UII:1150, C:298, O:45
mean equation UII:1141
multivariate UII:1516
Power ARCH (PARCH) C:296, O:43
power ARCH (PARCH) UII:1152
procedures UII:1148
robust standard errors UII:1144
test for UII:1092, C:299, O:46
threshold (TARCH) UII:1150
variance equation UII:1141
garch O:104, O:823
Gauss file UI:36, C:530, C:546
Gaussian distribution C:594
Gauss-Newton UII:2133, C:422, O:52, O:61, O:129
Gauss-Seidel algorithm UII:1827, UII:2134
Generalized autoregressive conditional heteroskedasticity
See ARCH and GARCH.
Generalized error distribution UII:1151, C:594
Generalized error function
CDF C:606
density C:608
inverse CDF C:616
Generalized inverse C:733
Generalized least squares See GLS
Generalized linear models
example UII:1293
forecasting UII:1302
link function UII:1290, UII:1307
overview UII:1287
performing in EViews UII:1289
quasi-likelihood ratio test UII:1278
residuals UII:1301
robust standard errors UII:1292
specification UII:1289
technical details UII:1305
testing UII:1303
variance factor UII:1284
Generalized method of moments, See GMM.
Generalized residual O:141
binary models UII:1241
censored models UII:1259
count models UII:1278
GLM UII:1301
ordered models UII:1252
score vector UII:1242
truncated models UII:1265
Generate series UI:197, C:373, O:623
by command UI:200
dynamic assignment UI:199
for pool UII:1854, O:525
implicit assignment UI:199
implicit formula UI:199
using samples UI:198
genr C:373, O:12, O:525, O:623
See also alpha.
See also series.
Geographic maps UI:645
Geomap UI:645, 0:247
attribute setting 0:261
border colors 0:258, 0:266
declaration 0:253
display attributes 0:251
display default map view 0:253
fill (background) color for shapes 0:262
font 0:268
legend 0:254
link series to shapefile 0:255
load shapefile 0:256
make display attributes series 0:256
mark areas to be invisible 0:257
mark areas to be visible 0:269
options 0:258, 0:266
geomap 0:253
Geometric mean C:575, C:610
Geometric moving average UI:205
getglobalc O:974
@getmaindiagonal C:722
@getnextname C:768
GiveWin data UI:395, C:349
Glejser heteroskedasticity test UII:1092, O:119
GLM
See Generalized linear models.
GLM standard errors C:303, C:304, C:339, C:340, C:376, C:438, O:52, O:83, O:108, O:151
Global breakpoint
estimation with 1:1338
tests UII:1104
Global optimum UII:2129
Global subroutine C:160
Global variable C:159
GLS C:421, O:128, O:527, O:829
detrending UII:1525
factor estimation O:207
pool estimation details UII:1881
weights UII:1917
gls O:207
@gmean C:575, C:610
GMM UII:975, UII:1623
bandwidth selection (single equation) UII:984
bandwidth selection (system) UII:1599
breakpoint test UII:990, O:58
continuously updating (single equation) UII:979, UII:984, C:379, O:110
diagnostics UII:986
dropped instruments UII:986
estimate single equation by UII:975, C:378, O:110
estimate system by UII:1592, O:824
HAC weighting matrix (single equation) UII:984
HAC weighting matrix (system) UII:1625
instrument orthogonality test UII:987, O:152
instrument summary UII:986, O:125
iterate to convergence (single equation) UII:979, UII:984, C:379, O:110
J-statistic (single equation) UII:976
kernel options (single equation) UII:984
kernel options (system) UII:1599
multi-equation UII:1592
N-step (single equation) UII:979, UII:984
one-step (single equation) UII:979, UII:984, C:379, O:110
panels UII:1919
prewhitening option (single equation) UII:984
prewhitening option (system) UII:1600, UII:1626
regressor endogeneity test UII:987, O:88
robust standard errors UII:980
system UII:1623
tests UII:986
user-specified weight matrix UII:984
weak instruments UII:988, O:194
White weighting matrix (single equation) UII:984
White weighting matrix (system) UII:1624
Windmeijer standard errors UII:981
gmm C:378, O:110, O:824
Godfrey heteroskedasticity test UII:1091, O:119
Goldfeld-Quandt UII:2132
Gompit models UII:1230, C:303, O:52
Goodness-of-fit O:38
adjusted R-squared UII:907, O:38
Andrews test UII:1238, UII:1285, O:180
binary models O:180
factor analysis UII:2055, O:206
forecast UII:1051
Hosmer-Lemeshow test UII:1238, UII:1284, O:180
R-squared UII:907
Google Drive UI:84, C:310, C:533, C:550
Gradients UII:2139
details UII:2139
display O:117, O:424, O:739, O:826
in equation UII:913, UII:1605
in logl UII:1506
in user defined optimization 1:246, C:433
saving in series UII:2141, O:139, O:426, O:742
summary UII:2140
grads O:117, O:424, O:739, O:826
Granger causality test UI:638, C:308, O:334
panel II:2010
VAR UII:1646, O:959
Graph O:270
add text C:50, 0:248, O:282
align multiple UI:822
align multiple graphs O:285
analytical graphs UI:723
area band UI:710
area graph UI:708, O:994
arrows UI:797, O:273
attribute setting O:314
automating UI:826
auto-updating UI:790, O:323
auxiliary graphs UI:742
average shifted histogram UI:728
axis O:286
axis borders UI:663
axis by command C:42
axis control UI:810
axis label format UI:694
axis labeling O:291, O:321
axis location by command C:45
axis See also Axis.
background color UI:809
background printing UI:809
band graph O:997
bar graph UI:708, O:999
basic customization UI:686
border UI:809
boxplot UI:739, O:1003
bubble graph O:1006
bubble plot UI:715
bubble triplet graph O:1006
categorical UI:809
categorical See also Categorical graphs.
change legend or axis name O:305
change types C:37
color by command C:39
color settings UI:809
combining UI:794
combining graphs UI:794
commands O:270
confidence ellipse UI:751
coordinates for positioning elements UI:795
create by command C:33
create group from O:304
create using freeze C:368
creating UI:789, UI:790
custom obs labels UI:811
customization UI:794
customization by command C:38
customize axis labels UI:694
customizing lines and symbols UI:814
data members O:272, O:405
data option UI:661
date label format UI:696
date label frequency UI:695
date label positioning UI:698
declaring O:299
distribution graph O:1007
dot plot UI:713, O:1014
drawing lines and shaded areas UI:796, O:293, O:296
ellipse O:277
empirical CDF UI:734
empirical log survivor UI:735
empirical quantile UI:736
empirical survivor UI:735
error bar UI:714, O:1018
extract from spool O:709
fill areas UI:705
first vs. all UI:675
fit lines UI:678
fit lines command specification O:1066
font UI:795, O:320
font options UI:820
frame UI:687
frame border UI:688
frame color UI:687
frame customization by command C:47
frame fill UI:809
freeze UI:789
freezing UI:790
frequency UI:663
grid lines UI:809
groups UI:668
high-low-open-close UI:714, O:1020
histogram UI:723
histogram edge polygon UI:727
histogram polygon UI:726
identifying points UI:657
indentation UI:809
insert in spool O:712
kernel density UI:729
kernel regression UI:745
label by command C:54
legend UI:701
legend appearance and placement O:302
legend by command C:49
legend font UI:703
legend options UI:813
legend placement UI:702
legend settings UI:813
legend text UI:703
line characteristics C:39
line formats UI:703
line graph UI:707, O:1022
lines UI:797
link frequency UI:663
location UI:689
means UI:661
merge C:37
merge multiple O:304, O:491
merging graphs O:299
merging multiple UI:106
mixed frequency data UI:672
mixed line UI:711, O:1026
modifying UI:806
multiple graph options UI:822
multiple series option UI:670
nearest neighbor regression UI:747
non-consecutive observations UI:809
observation graphs UI:707
observations to label UI:695
options for individual elements O:316
options for individual elements of a boxplot O:315
orientation UI:662
orthogonal regression UI:750
pairwise data UI:674
panel data II:1993
panel data options UI:665
patterns by command C:40
pie UI:721
pie graph O:1028
place text in UI:795, O:326
position UI:689, UI:822
print in color UI:824
printing UI:824
procs O:271
quantile-quantile UI:737, UI:738, UI:739
quantile-quantile graph O:1031
raw data UI:661
rectangles O:279
regression line UI:742
remove custom date labels UI:813
remove elements UI:805
rotate UI:662
rotation UI:695
sample break plotting options UI:809
save to disk C:484, 0:259, O:312
saving UI:825
scale UI:695
scatter UI:715
scatterplot (pairs) graph O:1042
scatterplot graph O:1035
scatterplot matrix UI:676
scores UII:2053
seasonal UI:721
series UI:659
series view UI:426
set axis scale O:314
set options O:306
settings for multiple graphs UI:821
shade options UI:820
shading by command C:51
size UI:688
size by command C:47
slider bar (pasting with) 1:872
sort O:324
sorting UI:804
sorting observations UI:804
spike UI:711
spike graph O:1047
stacked UI:675
symbol graph UI:707
symbols UI:703
template by command C:51
templates UI:816, O:325
text justification UI:795
text options UI:820
theoretical distribution UI:733
type UI:660, UI:669, UI:707, UI:807
update O:328
update settings UI:791, O:323
views O:271
XY area UI:719, O:1051
XY bar UI:720, O:1054
XY line UI:718, O:1056
XY pairs UI:675, O:1059
graph O:299
graphmode O:710
Greater than comparison C:275
matrix element by element C:714
Greater than or equal to comparison C:275
Grid lines UI:699
table UI:832
Grid search UII:2134
Group UI:206, UI:575, O:330
add member UI:575
add series O:334
adding series UI:576
adding to UI:135
attribute setting O:383
auto-series UI:205
convert to matrix C:271, C:730
convert to matrix (keep NAs) C:746
count of O:332
create UI:133, UI:206
creating using wildcards C:798
data members O:332
declare O:368
define members O:377
delete observations
descriptive statistics O:400
display format UI:134
display type UI:125
drop series O:363
duplicate observations O:365
edit mode default UI:2098
edit series UI:577
editing UI:135
element UI:207
fill (background) color for cells O:383
from series in graph O:304
graph view UI:600
graph views O:331
graphing UI:668
indentation O:391
make system of equations UI:640
members O:377
number of series UI:207
pool UII:1846
procs O:331
rearranging series UI:576
row functions UI:207, C:585
series names O:333
sort O:399
spreadsheet view UI:576
spreadsheet view defaults UI:2098
summaries UI:582, O:353, O:356
test for valid group C:770
text color for cells O:393
views O:330
group O:368
Group into bins option UI:430, UI:613
@groupid C:589
Group-mean DOLS 1:1989
Group-mean FMOLS 1:1987
Groupwise heteroskedasticity UI:617
Gumbel UI:734
