M
MA roots
MADMED
MADZERO
Maps
Markov switching VAR
O:956Match operator in database query
UI:345Match-merge
Mathematical functions
C:569Cholesky factorization
C:695column standard deviation
C:707column trimmed mean
C:708convert to other matrix objects
C:282covert from series or group (drop NAs)
C:704,
C:745covert from series or group (keep NAs)
C:746descriptive statistics
O:467element greater than
C:714element greater than or equal to
C:714element less than or equal to
C:716elementwise operations
C:277generalized inverse
C:733permute columns of using vector of ranks
C:736permute rows of using vector of ranks
C:694,
C:701place vector in column
C:700ranks of the elements of the matrix
C:735reverse sweep operator
C:740scale rows or columns
C:741stack lower triangular columns
C:755standardize (population)
C:745standardize columns of matrix
C:702trend coef for columns
C:708vertical concatenation
C:754Matrix commands and functions
Matrix concatenation
C:722Matrix cumulative sum
C:709Matrix operators
comparison operators
C:275order of evaluation
C:273Maximization
See also Optimization (user-defined).
matrix columns index
C:696matrix element by element
C:717Maximum absolute correlation
O:219Meta data
Metafile
save graph as Windows metafile.
UI:825Micro TSP
Microsoft Excel
Microsoft PowerPoint
pasting graphs and data into
1:865Microsoft Word
1:865MIDAS
exponential Almon weighting
II:1212Minimization
C:717in frequency conversion
UI:172mathematical functions
C:569relational comparisons involving
UI:195Mixed data sampling
Mixed frequency
MLE
Model
Model selection
Models
add factor assignment and removal
O:473add factor initialization
O:474append specification line
O:477break all model links
O:507diagnostic messages and iteration history
UII:1826display model check boundaries view
O:478dropping endogenous variables
O:483dropping linked objects
O:483editing scenario data
O:476exclude variables from solution
O:484make from equation object
O:140make from logl object
O:427make from pool object
O:531make from sspace object
O:742make from system object
O:832make from var object
O:942make graph of model series
O:488make group of model series
O:490options for solving
O:503options for stochastic simulation
O:486options for stochastic solving
O:505override add factors
O:475overrides in model solution
O:493reincluding variables
O:495replacing endogenous variables
O:495replacing linked objects
O:496replacing variables
O:497reverting variables to initial values
O:497simultaneous and recursive blocks
UII:1802solve control to match target
O:481trace iteration history
O:506update specification
O:508Moody’s Economy.com
C:349Moody’s Economy.com data
UI:400Moore-Penrose inverse of matrix
C:733Moving average (ARMA)
C:634coefficient variance decomposition
UII:1074Multiplication operator (*)
C:274Multivariate normal density
C:609Multivariate normal density (Cholesky inverse)
C:609Multivariate normal density (Cholesky)
C:609Multivariate normal density (inverse)
C:609Multivariate normal distribution
C:596Multivariate normal random number generator (Cholesky inverse)
C:617Multivariate normal random number generator (Cholesky)
C:617Multivariate normal random number generator (inverse)
C:617
