Object Reference : Object Command Summary : C
C
C
coef vector UII:900
constant in regression UII:900
Cache UI:417
call C:762
Call subroutine C:157
Cancel keystroke UI:98
Canonical cointegrating regression UII:1163, UII:1170, C:323, O:72
@capplyranks C:694, C:701, C:736
Case-sensitivity C:177
Categorical graphs UI:755
See also Graphs.
analytical UI:764
binning UI:773
category summaries UI:756
command specification O:1063
descriptive statistics UI:756
factor display settings UI:775
factor labeling UI:784
factor ordering UI:776
factors UI:772
identifying categories UI:767
line UI:760
specifying factors UI:772
summaries UI:756
Categorical regressor stats UII:1235, UII:1258, O:145
Categorize C:589, O:605
Category identifier
index C:589
Cauchy function 1:1318
Causality
Dumitrescu-Hurlin II:2011, O:334
Granger’s test UI:638, C:308, O:334
panel data II:2010
cause C:308, O:334
@cbeta C:606
@cbinom C:606
@cbvnorm C:606
@cchisq C:606
ccopy C:309
cd C:309
CD test UII:1956, II:2018, O:58, O:604
@cdetrend C:694, C:700
cdtest O:58, O:604
CEIC UI:367, C:348
CEIC data UI:367
@ceiling C:569, C:606
Cell
annotation UI:834
background color O:383, O:649, O:861
borders O:870
display format C:62
display format See Display format
font selection O:863
formatting UI:832, C:62
height O:868
indentation See Indentation
justification See Justification
merging UI:835
merging multiple O:872
selection UI:827
set text color O:874
text color O:393, O:657
width See Column width
@cellid UII:1897, C:606, C:628
censored C:310, O:61
Censored dependent variable UII:1253, C:310, O:61
estimation UII:1254
expected dependent variable UII:1259
fitted index UII:1259
forecasting UII:1259
goodness-of-fit tests UII:1260
interpretation of coefficient UII:1258
log likelihood UII:1254
residuals UII:1258
scale factor UII:1258
specifying the censoring point UII:1255
views UII:1258
Census UI:368
Census data UI:368
Census X-11
historical O:683
using X-12 UI:511, O:685
Census X-12 UI:509, O:685
seasonal adjustment options UI:510
Census X-13 UI:472, O:690
Centered moving average C:582, C:584, C:612, C:613
@cexp C:606
@cfdist C:606
cfetch C:312
@cfirst C:695
@cgamma C:606
CGARCH UII:1153
@cged C:606
Change default directory UI:83, C:309
checkderivs O:421
@chisq C:593, C:606
Chi-square
independence test in tabulation UI:615, O:365
statistic for Wald test UII:1078
test for independence in n-way table UI:616, O:365
test for the median UI:438, O:670
Chi-square function C:593
CDF C:606
density C:608
inverse CDF C:616
p-value C:593, C:606
random number generator C:616
Cholesky C:695
@cholesky C:695
Cholesky factor
in VAR impulse responses UII:1653
in VAR normality test UII:1649
chow C:313, O:63
Chow test C:313, O:63
breakpoint UII:1100
forecast UII:1116
n-step forecast UII:1122
one-step forecast UII:1122
Chow-Lin
frequency conversion method UI:173, UI:176, C:334
@chr C:644
Christiano-Fitzgerald band-pass filter UI:567, O:599
@cifirst C:695
@cilast C:696
@cimax C:696
@cimin C:696
@cintercept C:697
cinterval O:64
clabel C:314
clambdagraph O:66
@claplace C:606
Classification
from series UI:463, O:605
Classification table
binary models UII:1236
ordered models UII:1250
sensitivity UII:1237
specificity UII:1237
classify O:605
@clast C:697
@clear UI:214
clear 0:890
Clear history
alpha O:7, O:406, O:557, O:760
coef O:20
equation O:64
factor O:201
geomap 0:252
graph O:290, O:335, O:515
logl O:421
matrix O:437
model O:479, O:501
sample O:577
scalar O:584
series O:607
spool O:706
sspace O:734
svector O:766
sym O:775
system O:816
table O:848
text O:882
valmap O:898
VAR O:915
vector O:969
Clear remarks
alpha O:7
coef O:20
equation O:65
factor O:202
geomap 0:252
graph O:290
group O:336
link O:406
logl O:422
matrix O:437
model O:479
pool O:515
rowvector O:557
sample O:577
scalar O:584
series O:607
spool O:707
sspace O:735
string O:760
svector O:767
sym O:776
system O:816
table O:849
text O:882
valmap O:899
var O:916
vector O:969
clearerrs C:762
clearhist O:7, O:20, O:64, O:201, 0:252, O:290, O:335, O:406, O:421, O:437, O:479, O:501, O:515, O:557, O:577, O:584, O:607, O:706, O:734, O:760, O:766, O:775, O:816, O:848, O:882, O:898, O:915, O:969
clearremark 0:252
clearremarks O:7, O:20, O:65, O:202, O:290, O:336, O:406, O:422, O:437, O:479, O:515, O:557, O:577, O:584, O:607, O:707, O:735, O:760, O:767, O:776, O:816, O:849, O:882, O:899, O:916, O:969
cleartext O:916
Cleveland subsampling UI:750
@clogistic C:606
@cloglog C:590
@clognorm C:606
Close
EViews UI:98, C:358
object UI:2091
window C:314
workfile C:522
close C:314
Cloud drive UI:84, C:310, C:533, C:550
Cluster
robust standard errors UI:52, UII:933
Cluster robust (QML) standard errors O:52, O:61, O:83, O:108, O:113, O:151, O:187
Clustering
by cross-section UII:1884, UII:1887, UII:1888
by period UII:1883, UII:1887, UII:1888
@cmax C:697
@cmean C:697
@cmedian C:698
@cmin C:698
@cnas C:698
@cnegbin C:606
@cnorm C:606
@cobs C:699
Cochrane-Orcutt UII:968, UII:1037
Coef O:18
attribute setting O:27
data members O:19
declare O:21
display name O:22
fill values O:23, O:617
graph views O:18
indentation O:28
procs O:19
spreadsheet view O:30
views O:18
coef O:21
Coef (coefficient vector)
default UII:900
update from equation UII:914
coefcov O:65, O:422, O:516, O:735, O:817
Coefficient
common (pool) UII:1864
covariance matrix UII:911, O:65, O:422, O:516, O:735, O:817
covariance matrix of estimates UII:913
cross-section specific (pool) UII:1864
diagnostics UII:1070
elasticity at means UII:1070, O:67
estimated from regression UII:905
heteroskedasticity consistent covariances UII:930
maximum number in default UII:1250
recursive estimates UII:1123
regression UII:905
restrictions UII:902
scaled UII:1070, O:67
See coef.
setting initial values UII:951, UII:2127
standard error UII:906
standardized UII:1070, O:67
tests UII:1070, UII:1076
update default coef vector O:192, O:431, O:548, O:755, O:841
variance decomposition UII:1074, O:84
vectors of UII:914
Coefficient restrictions UII:1510
confidence ellipse O:59, O:420, O:513, O:733, O:815
cross-equation UII:1594
Coefficient uncertainty UII:1799, UII:1815, UII:1825
coefmatrix O:66
coefscale O:67
coint C:315, O:336, O:516, O:917
Cointegrating regression UII:1161, C:323, O:72
equation specification UII:1164
panel See Panel cointegrating regression.
Cointegrating regressors UII:1165
panel 1:1974
Cointegrating relation
ARDL O:71
Cointegration UII:2023
See also Cointegrating regression.
ARDL models II:1191
Engle-Granger test C:315, O:67, O:336
Hansen instability test UII:1181, O:67
Johansen test O:917
make cointegrating relations from VEC O:941
panel testing II:2016, UII:2036
Park added variable test UII:1184, O:67
Phillips-Ouliaris test C:315, O:67, O:336
pooled data testing UII:1858
regression UII:1161
residual tests UII:1176, UII:2032, O:67
restrictions UII:1673, UII:2030
test UII:1176, UII:2032, C:315, O:336, O:516
test critical values UII:2026, UII:2041
test from a VAR O:917
VAR UII:2023
cointgraph O:71
cointreg C:323, O:72
@colcumprod C:699
@colcumsum C:699
@coldemean C:700
Collinearity UII:917
coefficient variance decomposition UII:1074, O:84
test of UII:1073, UII:1074, O:84, O:192
variance inflation factors UII:1073, O:192
Color
EViews application UI:2090
graph frame UI:687
keywords for specifying 0:250, 0:258, 0:265, 0:267, O:274, O:278, O:280, O:284, O:288, O:295, O:298, O:303, O:311, O:319, O:327, O:354, O:359, O:387, O:396, O:652, O:661, O:862
printing in UI:824
@RGB specification 0:250, 0:258, 0:265, 0:267, O:274, O:278, O:280, O:284, O:288, O:295, O:298, O:303, O:311, O:319, O:327, O:354, O:359, O:387, O:396, O:652, O:661, O:862
tables UI:833
colplace C:700
@colstdize C:702
@colstdizep C:703
Column
extract from matrix C:701
matrix headers O:462
number of columns in matrix C:586, C:606, C:702
place in matrix C:700
stack matrix C:755
stack matrix (lower triangle) C:755
unstack into matrix C:753
unstack into sym (lower triangle) C:754
width See also Column width
Column statistics
First non-missing C:695
First non-missing index C:695
intercept from trend regression C:697
last non-missing C:697
last non-missing index C:696
maximum C:697
maximum index C:696
means C:697
median C:698
minimum C:698
minimum index C:696
NAs, number of C:698
observations, number of C:699
sum of squares C:708
sums C:707
Column width UI:832, C:60, C:487
coef O:29
group O:397
matrix O:466
rowvector O:573
series O:662
sym O:800
table O:875
vector O:987
@columnextract C:701
@columns C:586, C:606, C:702
COM session
close C:556
command line C:559, C:560
EViews as client C:181
EViews as server C:181
EViews log C:559
get object C:556
open C:560
put names C:684
R packages C:562
run command C:565
send object C:563
Combination testing UI:453
Command
object command auto-complete UI:15, C:9
object name auto-complete UI:14, C:8
Command capture C:3
add comment C:330
Command explorer C:6
Command window UI:91, C:5
docking and moving C:10
history of UI:92
commandcap C:330
Commands
auxiliary C:26, C:285
basic command summary C:285
batch mode C:17
capture from user-interface C:3
documentation C:387
execute without opening window C:353
history of UI:92
interactive mode C:5
object assignment C:19
object command C:21
object declaration C:20
save record of C:3, C:5
comment O:707, O:849
Comments UI:116, C:73
program C:120, C:129
spool UI:844, O:707
tables UI:834, O:849
Common sample UI:195
Communalities UII:2048
Commutation matrix C:703
@commute C:703
compare O:480
Comparing workfiles and pages UI:80, C:523
Comparison operators UI:190, C:275
with missing values UI:195
Compatibility C:174
Complementary log-log function C:590
Component GARCH UII:1153, C:296, O:43
Component plots UI:623, O:378, O:638
Concatenation C:78
@cond C:703
Condition number of matrix C:703
Conditional independence UI:616
Conditional standard deviation
display graph of UII:1147, O:104, O:823
Conditional variance UII:1135, UII:1137, UII:1138
forecast UII:1148
in the mean equation UII:1139
make series from ARCH UII:1150, O:138, O:830
Confidence ellipses UI:751, UII:1070, O:59, O:420, O:513, O:733, O:815
Confidence interval UII:1070, O:64
ellipses UII:1070
for forecast UII:1051
for stochastic model solution UII:1823
Constant
in equation UII:900, UII:906
in ordered models UII:1248
Container C:26
database C:28
workfile C:26
Contemporaneous covariance (in panels) II:1999
Contingency coefficient UI:616
Continuation character in programs C:120
Continuously updating GMM
single equation UII:979, UII:984, C:379, O:110
Contracting data UI:302
control O:481
Control variable C:130
as replacement variable C:135
in while statement C:151
save value to scalar C:130
Convergence criterion UII:2126, UII:2139, C:422, C:429, O:52, O:61, O:129, O:130, O:147, O:940
default setting UI:2101
in nonlinear least squares UII:949, UII:954
in pool estimation UII:1867
Convert
alpha to svector C:745
date to observation number C:651
matrix object to series or group C:730
matrix objects C:269, C:282
matrix to sym C:724
observation number to date C:90, C:91, C:658
panel to pool UI:309
pool to panel UI:315, C:460
scalar to string C:661
series or group to matrix (drop NAs) C:704, C:745
series or group to matrix (keep NAs) C:746
series to matrix/vector C:271
string to scalar C:90, C:133, C:671
sym to matrix C:719
table to matrix C:751
@convert C:271, C:704
Coordinates for legend in graph O:302
Copy UI:302
and paste UI:118, UI:836, 1:865
and paste See also OLE.
by link UI:303
by value UI:304
command UI:171
data UI:162
data cut-and-paste UI:148
database UI:351, C:344
matrix C:266
objects UI:117, C:29, C:331
pool objects UII:1844
table to clipboard UI:836
to and from database UI:333
to spool UI:841
workfile page C:444
copy C:331
Copy special 1:892
copyrange O:850
copytable O:851
@cor C:574, C:606, C:704
cor C:338, O:344
correl O:81, O:347, O:608, O:817, O:919
Correlation C:574, C:606, C:704
cross C:342, O:351, O:817
from matrix O:438
from sym O:776
matrix C:338, O:344
moving C:583, C:585, C:612, C:613
Correlogram UI:448, UI:451, UII:1002, C:342, O:81, O:347, O:351, O:608, O:817, O:919
ARMA models UII:1023
autocorrelation function UI:448
cross UI:631
partial autocorrelation function UI:449
Q-statistic UI:450
squared residuals UII:1088, UII:1147, O:81
VAR UII:1647
correlsq O:81
@cos C:592, C:606
Cosine C:592, C:606
@count UI:207
count C:339, O:82
Count models UII:1273, C:339, O:82
dependent variable frequencies O:85
estimation UII:1274
forecasting UII:1278
negative binomial (ML) UII:1275
Poisson UII:1274
QML UII:1276
residuals UII:1278
@cov C:574, C:606, C:705
cov C:341, O:348, O:438, O:441, O:776, O:779, O:970
Covariance C:574, C:606, C:705, C:706
from matrix O:441
from sym O:779
from vector O:970
matrix C:341, O:348
matrix for panel data O:635
matrix, of estimated coefficients UII:911
matrix, systems UII:1605
moving C:582, C:583, C:584, C:585, C:612, C:613
Covariance analysis UI:600
details UI:608
panel II:1999
Covariance proportion UII:1053
@covp C:574, C:705
@covs C:574, C:706
@cpareto C:606
@cpoisson C:606
@cprod C:706
Cragg-Donald UII:988, O:194
Cramer’s V UI:616, O:365
Cramer-von Mises test UI:441, O:612
Create
database UI:327, C:343, C:346
dated data table UI:583
factor UII:2044
graph UI:789
graph by command C:33
group UI:133, UI:206
link UI:255
objects UI:105
page UI:70
program C:119
series UI:124, UI:197
spool UI:839
spool by command C:69
table UI:827, C:57
text object UI:838
workfile UI:30, C:525
workfile page C:446
cross C:342, O:351
Cross correlation UI:631, C:342, O:351
Cross correlogram UI:631, O:347
Cross product C:732
Cross section
pool identifiers UII:1843
specific series UII:1845
summaries UII:1906
SUR UII:1883
Cross section dependence test UII:1956, II:2018, O:58, O:604
Cross section member
add to pool O:334, O:513
define list of in a pool O:518
text identifier O:511
Cross-equation
coefficient restriction UII:1590, UII:1594
correlation UII:1591, UII:1592
weighting UII:1590
@crossid UII:1896, C:628
@crossidest O:511
@crossids O:511
Cross-tabulation O:365
@cslope C:706
@cstdev C:707
@cstdevp C:707
@cstdevs C:707
@csum C:707
@csumsq C:708
CSV UI:837
save table to file O:858
@ctdist C:607
C-test UII:987, O:152
@ctrendcoef C:708
@ctrmean C:708
Cubic
frequency conversion method UI:173, UI:174
CUE (continuously updating GMM) See Continuously updating GMM
@cumbmax C:581, C:607
@cumbmean C:580, C:607
@cumbmedian C:581
@cumbmin C:581, C:607
@cumbnas C:581, C:607
@cumbobs C:581, C:607
@cumbprod C:580, C:607
@cumbquantile C:581
@cumbstdev C:580, C:607
@cumbstdevp C:580, C:607
@cumbstdevs C:580, C:607
@cumbsum C:580, C:607
@cumbsumsq C:581, C:607
@cumbvar C:580, C:607
@cumbvarp C:580, C:607
@cumbvars C:580, C:607
@cummax C:579, C:607
@cummean C:578, C:607
@cummedian C:580
@cummin C:579, C:607
@cumnas C:579, C:607
@cumobs C:579, C:607
@cumprod C:578, C:607, C:709
@cumquantile C:580
@cumstdev C:579, C:607
@cumstdevp C:579, C:607
@cumstdevs C:579, C:607
@cumsum C:578, C:607, C:709
@cumsumsq C:579, C:607
Cumulative distribution UI:734
computation UI:734
Cumulative distribution function O:1007
Cumulative product C:709
matrix column C:699
Cumulative statistics
functions UI:193, C:578
maximum C:579, C:581, C:607
mean C:578, C:580, C:607
Median C:580, C:581
min C:579, C:607
minimum C:581, C:607
NAs, number of C:579, C:581, C:607
observations, number of C:579, C:581, C:607
product C:578, C:580, C:607
Quantiles C:580, C:581
standard deviation C:579, C:580, C:607
sum C:578, C:580, C:607
sum of squares C:579, C:581, C:607
variance C:579, C:580, C:607
Cumulative sum C:709
matrix column C:699
@cumvar C:579, C:607
@cumvarp C:579, C:607
@cumvars C:579, C:607
@cunif C:607
Current
date as string function C:763
time function C:781
Custom database C:189
Customization
graphs UI:686
CUSUM
sum of recursive residuals test UII:1120, O:168
sum of recursive squared residuals test UII:1121, O:168
@cvar C:709
cvardecomp O:84
@cvarp C:710
@cvars C:710
cverrortable O:85
@cweib C:607
