S
Sample
change using for loop
C:147display sample specification in
O:582earliest of first panel obs
C:493earliest of last panel obs
C:493latest of first panel obs
C:493latest of last panel obs
C:493number of observations in
C:622retrieve current default
C:622selection and missing values
UI:139set sample specification in
O:581specifying sample object
UI:145specifying samples in panel workfiles
UII:1900using sample objects in expressions
UI:145Samples
SAR(p)
save as new workfile
UI:64workfile precision and compression
UI:65Scale rows or columns of matrix
C:741Scaling
with confidence ellipse
UI:751with kernel regression fit
UI:745with orthogonal regression line
UI:750with regression line fit
O:371equation data member
O:39Seasonal
Census X-11 (historical)
UI:518Second moment matrix
C:724Seed random number generator
C:479Select
Selection model
Sensitivity of binary prediction
UII:1237Seqiuence
Sequential breakpoint
Sequential LR tests
C:153Serial correlation
multivariate VAR LM test
O:911Serial correlation test
auto-updating and databases
UI:215convert to matrix (keep NAs)
C:746extract observation
C:621fill (background) color for cells
O:649frequency conversion default method
O:647text color for cells
O:657using expressions in place of
UI:201setattr
O:14,
O:27,
O:171,
O:238,
0:261,
O:314,
O:383,
O:415,
O:430,
O:462,
O:500,
O:541,
O:570,
O:581,
O:586,
O:647,
O:721,
O:750,
O:763,
O:769,
O:797,
O:837,
O:860,
O:886,
0:894,
O:901,
O:954,
O:984 Shadowing of object names
UI:350Shape
Shapefile
sheet
Sign
matrix element by element
C:743Signal variables
Simple switching
Singular matrix
Slope equality test
O:159Slope equality test (quantile regression)
UII:1480Smooth transition regression
Smoothing
Snapshots
Solve
Source
field in database query
UI:347Spawn process within EViews
C:496Spearman covariance
Spearman rank correlation
UI:600Spearman rank covariance
Spearman rank-order
Specification
Specification test
Specification view
Specificity of binary prediction
UII:1237add objects by command
C:70declare spool object
O:723display name by command
C:72horizontal indentation
O:711naming objects by command
C:72show objects in spool
O:723table and text display mode
O:723vertical indentation
O:725Spreadsheet
Spreadsheet view
Squared multiple correlation
O:242append specification line
O:733coefficient covariance
O:735display signal graphs
O:750make Kalman filter from
O:741specification display
O:755Stack
sym matrix by lower column triangle
C:755Standard error
retrieve from equation
O:39retrieve from system
O:806Standard errors
Start
UI:346field in workfile details
UI:52user defined optimization 1:246
final one-step ahead predictions
O:752Statistical distribution functions
C:592Statistics
compute for subgroups
O:666stats
Stochastic equations
as replacement variable
C:134assign to table cell
C:58convert date string to observation
C:90,
C:91convert date value into
C:650convert date value to string
C:106convert from a number
C:661convert into date value
C:651convert number to string
C:89current date as a string
C:91display view of string
O:764insert string into another string
C:85,
C:652relational comparison
C:79relational comparisons with empty strings
C:81replace portion of a string with new string
C:86,
C:659substring from location
C:657test for inequality
C:657test two strings for equality
C:83test two strings for inequality
C:83trim spaces from left end
C:656trim spaces from right end
C:660String list
Structural change
optimization 1:243
Subtitle
Subtraction operator (-)
C:274Sum of squared residuals
Summary statistics
estimating by command
O:838create from string list
C:90make from text object
O:886
transition probabilities
O:945SwitchingVAR
switching intercept likelihood
UI:1725create from lower triangle of square matrix
C:724create from scalar function
C:721create square matrix from
C:719descriptive statistics
O:801scale rows and columns
C:741Symmetric matrix
Symmetrically trimmed residuals
UII:1261append specification line
O:809coefficient covariance
O:817estimation covariance
O:821full information maximum likelihood
UII:1592
